95 7.3 no start, everything looks ok on scanner - PowerStrokeNation : Ford Powerstroke Diesel Forum
 3Likes
post #1 of 27 (permalink) Old 04-18-2018, 12:00 AM Thread Starter
Hi guys,
I have a 95 f250 with the 7.3. Cranks but won't start, zero fuel out the tail pipe. Replaced the mech fuel pump, fuel squirts out of the schrader valve on the regulator if i open it, I haven't measured pressure while cranking but its definitely building some pressure.
I can't post a picture here but Ive got it hooked up to my laptop using FORscan, it quickly builds ICP to 3200 PSI while cranking, IPR goes to 50% and stays constant at 50 while cranking. Injector pulse width is between 3.8 and 4 ms while cranking. Injectors all pass the buzz test but some have a slightly different pitch sound, is that normal?
CPS is new, I'm only seeing 110-120 rpm while cranking, but still with everything else looking ok on the scanner I should at least be getting some fuel out the tailpipe right? Or am I wasting my time diagnosing more without getting it to crank faster
would love some ideas! thanks
stevey is offline
post #2 of 27 (permalink) Old 04-18-2018, 03:18 AM
Trust me, I got this...
Cummins Junkie's Avatar
Garage
Re: 95 7.3 no start, everything looks ok on scanner
You check all the fuses? in cab and under hood?
Shoulda bought a Cummins.
1997 F250 7.3L XLT, 4x4, 5spd, 315K, TS chip, BD Turbo-Thruster II, Donaldson 6637 filter, 4" straight piped dual exit SOLD
1995 F350 CCLB 6.0L WIP
Pain is inevitable. Suffering is optional.
Cummins Junkie is offline
post #3 of 27 (permalink) Old 04-18-2018, 02:27 PM
don't play well w others
Dustybumpers's Avatar
My 02 wound up being an ignition switch
Shake the column pretty good, and try starting again
Sent from my SM-G900V using Tapatalk
Charlie
"A common mistake people make when trying to design something completely fool proof, is to underestimate the ingenuity of a complete fool."
Dustybumpers is offline
post #4 of 27 (permalink) Old 04-18-2018, 03:18 PM
Moderator
Sbluke55's Avatar
It sounds like a fuel problem since your getting injector pulse width.
Is you fuel bowl full
01 f-250, Standard
Sbluke55 is offline
post #5 of 27 (permalink) Old 04-18-2018, 08:28 PM
Master BS'er
jamiesaun's Avatar
Agreed. Either no fuel to the injectors or low compression.
Brother James
Ps...Im pretty frickin awesome!
jamiesaun is offline
post #6 of 27 (permalink) Old 04-19-2018, 02:08 AM Thread Starter
If I had low compression I'd still get some fuel out the tailpipe though right? I can put my face at the tailpipe while my buddy cranks it and doesn't smell of diesel at all
The ignition switch is definitely suspect I have to wiggle it a bit to start. But I didn't think that was the issue since I wouldn't have all the scanner info if the ignition was off?
The fuel bowl is full, I filled it with fresh fuel and new filter
stevey is offline
post #7 of 27 (permalink) Old 04-19-2018, 02:09 AM Thread Starter
But yeah there can't be fuel at the injectors since none is coming out. do the fuel regulators on the side of the bowl ever go bad?
stevey is offline
post #8 of 27 (permalink) Old 04-19-2018, 02:10 AM Thread Starter
Thanks for all the suggestions
stevey is offline
post #9 of 27 (permalink) Old 04-19-2018, 02:10 AM
Mine did everything but start. Got vodes, buzz test, etc
Once I shook the column while holding the lever it started
Hopefully is same for you
Charlie
post #10 of 27 (permalink) Old 04-19-2018, 02:35 AM
Master BS'er
jamiesaun's Avatar
How fast is it cranking?
Sent from my SM-G950U using Tapatalk
Brother James
