1997 7.3 Fluctuating Fuel Pressure - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 2 (permalink) Old 04-17-2018, 06:19 PM Thread Starter
MattieS's Avatar
Does anyone know if fluctuating fuel pressure is normal for the obs 7.3?
I have an electric fuel pressure gauge installed on the fuel bowl, and at idle it jumps randomly between 50 and 70 psi (I have the FPR shimmed to 70psi) and under WOT the pressure drops off to about 35 psi.
I've read that the pressure shouldn't be steady due to the mechanical fuel pump, but this seems like a lot of variation to me. At idle my truck shakes considerably, and seems to be lacking power.
I've changed the fuel filter and pulled the fuel tanks to check if the in-tank screens were plugged, but there are no screens. Hoping someone has some advice. Thanks.
MattieS is offline
post #2 of 2 (permalink) Old 04-17-2018, 06:52 PM
HilhavenFarm's Avatar
Re: 1997 7.3 Fluctuating Fuel Pressure
If no shower heads are present then how are hoses positioned for fuel pickup? Are hoses collapsing, restricting fuel out of tank?
I had this in an older IDI that someone had fixed without shower heads. I redid with E5TZ-9J306-BA and it worked fine afterwards.
My .02
1996 F350 XL Crew Cab LB 4x4 3:55
Former Ft. Bragg/Pope AFB Truck
DieselSite Coolant Filter
Riff Raff Diesel Turbo & Y Boot Kit
Riff Raff Diesel HPX
Mile Marker 449SS Manual Hubs
1987 F250 XLT Lariat LB 2WD 4:10
6.9/7.3 IDI Swap-SOLD
2010 John Deere 5055D
1974 Deutz 5506
2950 hours-"The Tank"
HilhavenFarm is offline
