slave cylinder - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 03-13-2010, 02:51 AM Thread Starter
slave cylinder
did a couple searches but couldnt really find what i needed. long storry short. broke the old one.. put a new one one. no pressure now.. how to bleed it? and yes it has the bleeder valve on the cylinder itself. pedal falls to the floor. thanks guys
95' F250 SCLB ZF5 4x4 4.10 white
Leveled, 33's, 325hp, smoked everything SOLD
97' f250 CCSB auto, 4x4, d60 swap, 4.10 white
4 or 6in lift?, 35x12.50 terra grapplers, tymar intake, straight pipe, cales tunes,
shiftracing17 is offline
post #2 of 5 (permalink) Old 03-13-2010, 03:07 AM
blacksmokingplumber's Avatar
Re: slave cylinder
Get a beer, get in truck pump pedal till beer is gone. Get another beer, Bleed cylinder. These darn things should be installed and then pumped like 50 times to do someting magic. I know it sounds stupid but i was told by an old timer to do it that way and has been great for me. I have done about a dozen of these in different trucks. Someone else may have something better but that is my fail safe.
2001 F-250 SC/SB 4x4 Auto
"All I want to do is Burp, Puke and Fart, In that order."
"Powerstroke Performance Headquarters!"
blacksmokingplumber is offline
post #3 of 5 (permalink) Old 03-13-2010, 04:02 AM
OverFuelingForYourPlesure
pontiacross's Avatar
Re: slave cylinder
I usually take the cylinder off the transmission, and point it so the line is on the top, then start working the rod in and out. that should get the majority of the air out of the cylinder. then put it back on the transmission and finish bleading it with the screw.
Ross
2.6 modified street pulling truck "The Lone Stroke
-1996 f350, stock bottom end! swamps 400/400% injectors, swamps BFH turbo, swamps IDM, Swamps tunes, BTS oil, springs, studs, tubes, fuel system, water to air cooler, and much more...
-97 f350 4x4 CCLB tow rig
pontiacross is offline
post #4 of 5 (permalink) Old 03-13-2010, 05:10 AM
Patrick Feeley's Avatar
Re: slave cylinder
First I unhook the master cylinder rod from the pedal linkage (more important step than you might think). Then I unclip the slave from the bellhousing, make sure everything is pointing uphill and cycle the slave slowly by hand about ten times or so. Reinstall slave and reconnect master rod. It's worked for me every time. Cheers!
Patrick Feeley is offline
post #5 of 5 (permalink) Old 03-13-2010, 08:26 PM Thread Starter
Re: slave cylinder
thanks guys its good now!
