Clutch issues - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 04-16-2018, 01:57 AM Thread Starter
Clutch issues
Hi all thanks in advance the help just brought a 97 f450 and you have to hold the clutch pedal down as hard as you can to start the truck and as the truck warms up it gets harder and harder to shift until you have to force it out of gear and in to the next any help would be awesome
Scott1315 is offline
post #2 of 4 (permalink) Old 04-16-2018, 02:25 AM
dogpile
Re: Clutch issues
It's not releasing, if your hydraulics are working it's probably new clutch time.
Gerald Small is offline
post #3 of 4 (permalink) Old 04-17-2018, 01:08 AM
Patrick Feeley's Avatar
Re: Clutch issues
Check the clutch pedal and linkage bushings for slop as they are infamous for it. Also make sure you inspect the clutch master rod eye that the bushing goes into for abnormal wear as simply putting a new bushing in a worn eye will disintegrate the bushing in short order. Cheers!
Patrick Feeley is offline
post #4 of 4 (permalink) Old 04-23-2018, 04:42 PM
USAF
Re: Clutch issues
As said above check all the bushings and pedal assembly under the dash. Just went through this myself. Also...if you have a spongy clutch you can bleed it using the bleeder valve and an Allen wrench underneath the truck. When you add the DOT 3 (if need be) make sure you remove the rubber seal that is at the top of the reservoir, or you'll be adding in vain.
Questions bout my struggle pm me anytime brother.
-Johnny
97 F250 7.3 SCLB ZF5 manual, 226,xxx. Bought at ~155,xxx stock. Still pretty much stock except: aftermarket turbo back exhaust, cold air intake, and full bumper replacement (deer crusher).
Johnny Yee Yee is offline
