missing under load - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 03-25-2018, 11:36 PM Thread Starter
missing under load
I have a 1995 (build date of 10/94) f-350 I purchased the truck in 1995 from the original owner with 30k miles on it.. It has 162k miles on it. I had a solid flywheel and new clutch installed, I rebuilt the fuel bowl and regulator, new fuel pump an rubber lines. It suddenly started to shake more and is missing under acceleration. It went from running fine to it current state as I was pulling in my driveway. I have checked the connectors that plug into the valve covers and they look fine except the rear drive side clip is broken and when i removed it, it had oil inside the plug. I pulled driver side valve cover and all looked fine underneath. All connections tight and nothing broken or melted. Anyone have any ideas what may be the cause? I have no check engine light. The only thing i can see different is if i rev the engine and hold it at a constant rpm, the tach will slowly drop a couple of hundred rpm.
3strucking is offline
post #2 of 5 (permalink) Old 03-28-2018, 05:45 PM
Re: missing under load
i actually have this same problem , replaced fuel bowl assembly new, fuel pump new, valve cover gaskets new, and about to do the same rear wire connector tab broke on mine also at napa there 30$ but i see online at some diesel sites can get around 12-15$ a peice, im just hoping a injector aint starting to go or hybrid time lol
also i cant get mine to throw a code either and sometimes my code reader wont connect to pcm
97biggreen is offline
post #3 of 5 (permalink) Old 03-29-2018, 01:54 AM
Patrick Feeley's Avatar
Check your oil level. Check your fuel pressure at the Schrader valve on the fuel bowl. Also, if the wires/pins aren't melted, you can get a connector repair kit and just replace the connector shell piece with the broken tab (just get the wires in the same order). Cheers!
Patrick Feeley is online now
post #4 of 5 (permalink) Old 04-02-2018, 12:20 AM Thread Starter
I got AE with the ford bundle and ran buzz test. #5 sounds real weak, 6 sounds bad also.
post #5 of 5 (permalink) Old 04-02-2018, 12:23 AM Thread Starter
I need to also add that i have a hard time getting it started unless i plug it up. Its in the 70's here today and it took around 10 trys to get it started. Its been that way a while.
