Codes - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 03-23-2018, 06:58 PM Thread Starter
rjwarrior88's Avatar
Codes
Hey guys just pulled some codes with the car gauge pro app. I'm wondering what how to address them. CEL only comes on in cold mornings for about 5 to ten seconds and the truck runs fine.
File Type: jpg Screenshot_20180322-144636_1521827912267.jpg (7.4 KB, 9 views)
rjwarrior88 is offline
post #2 of 5 (permalink) Old 03-23-2018, 07:05 PM Thread Starter
Also my dad's truck(white truck) has a bunch of codes as well after running the injector buzz test. All injectors buzzed evenly i don't know if that helps. It runs fine once you let it idle for about 20 minutes and drive it about half a mile. If it's cold it won't maintain speed and loss of power unless it's accelerating. Not sure how to explain it.
File Type: jpg Screenshot_20180322-143102_1521828277855.jpg (13.4 KB, 6 views)
post #3 of 5 (permalink) Old 03-23-2018, 07:17 PM
Bugman's Avatar
Re: Codes
Here is a list of the codes and possibly what caused them.
1995/1996 Powertrain Control System Electronics Diagnostic Guide - 1994-1997 Power Stroke FAQ
Bugman is online now
post #4 of 5 (permalink) Old 03-24-2018, 02:02 AM
Patrick Feeley's Avatar
Re: Codes
Is your Dad's truck a California 97 truck (or later)? The 1391 and 1393 codes are for glowplug monitoring systems that the 94-96 trucks did not have (and why you don't see them in the link Bugman posted). Cheers!
Patrick Feeley is offline
post #5 of 5 (permalink) Old 03-24-2018, 02:45 AM Thread Starter
I'm not sure. He bought it used and didn't get much if any info of where it came from. nor anything about the precious owner's. But it is a 97
