1997 Powerstoke - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 03-21-2018, 03:45 PM Thread Starter
1997 Powerstoke
Hello I'm new to the Nation just bought a 97 F250 7.3 with 199k, im having some similar problems has a few guys I have been reading but never has anybody replied what the solution maybe it cranks over alot before i can get it running then runs like cap has no power with very rough idle, I've replaced IPR, ICP, CPS checked relays ect...would my next step would be uvch?
Dustin Feuerborn is offline
post #2 of 6 (permalink) Old 03-21-2018, 06:48 PM
Native Texan
masakimm's Avatar
Garage
Re: 1997 Powerstoke
Welcome to the nation.
Upgrades:
masakimm is offline
post #3 of 6 (permalink) Old 03-22-2018, 06:19 AM Thread Starter
Found it
post #4 of 6 (permalink) Old 03-22-2018, 12:00 PM
dogpile
Re: 1997 Powerstoke
Good job, welcome BTW.
Gerald Small is offline
post #5 of 6 (permalink) Old 03-22-2018, 06:33 PM
Re: 1997 Powerstoke
Looks like you will be needing VC gaskets, UVCH pigtails, and Injector harness pigtails. If you look around, some of the online vendors sell them together as a kit at a discounted price. Some have options to include new glow plugs as well. When you replace the UVCH parts, be sure the glow plug wires underneath don't rub on the pushrods or rocker arm mounts. Not a really fun job, but best to do it right the first time.......
dragondave is offline
post #6 of 6 (permalink) Old 03-25-2018, 12:39 PM
Re: 1997 Powerstoke
Welcome to PSN, the harness, valve cover gasket etc., I have purchased from Riffraff Diesel Performance out of Oregon. Great service and good prices (least compared to Western Canada). I’d recommend using stock parts for replacement as they will last longer and are good quality. Also when I replace my plugs I usually apply some dialectric grease at the connections. There is a repair kit you can get that has a small screw driver like tool (flat blade, green handle), to aid in unsnapping harnesses, well worth getting that. Lastly while you're under the VCs I’d check and replace all the glow plugs.
cheers,
j
Tan white tan 97 ECLB, D60 PMF, RSK SD springs front, airs bags rear, 4:10, intake, FFD 205/30s, DP 4 exhaust DIY E-fuel, ZF-5 now
B&W turnover 5th wheel with Anderson hitch.
JCart is offline
