Obs hpop and fuel pump - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 3 (permalink) Old 03-20-2018, 12:30 AM Thread Starter
So i have a 95 7.3 and I pulled the motor to rebuild it and before I tear the hpop and fuel pump off i was wondering if either of them ran off of the motor timing or if you can just take them off and put them back on in any position.
Macher7.3 is offline
post #2 of 3 (permalink) Old 03-20-2018, 02:21 AM
Patrick Feeley's Avatar
Re: Obs hpop and fuel pump
You can just take them off. They are not timed (HPOP is gear driven and fuel pump runs off a lobe on the cam). Cheers!
Patrick Feeley is offline
post #3 of 3 (permalink) Old 03-20-2018, 02:35 AM
Bugman's Avatar
Odds are when you pull the fuel pump the plunger for it will fall down into the pan. But since you will be taking that off also you can just pull it out of the pan and replace it onto the pump.
Bugman is offline
