Coolant flush, what coolant to put back in - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 03-17-2018, 03:11 AM Thread Starter
After reading lots of different information, I have come to the conclusion that I should refill my 1997 7.3 with motorcraft green vc5 coolant and add two or three bottles of vc8 additive. Does this sound correct? A reputable diesel shop nearby swore that I would be ok using an ELC coolant without sca for my year 7.3 but I have read about injector cup issues caused by this. Options?
Workman is offline
post #2 of 6 (permalink) Old 03-17-2018, 01:00 PM
Re: Coolant flush, what coolant to put back in
Pre 99 you don't want to use ELC coolant, you want to use conventional green coolant and put a SCA additive in to keep from cavitating. I just use the motorcraft VC8 additive.
Jeremyd86 is offline
post #3 of 6 (permalink) Old 03-18-2018, 04:45 AM
​ DieselDC's Avatar
Use green coolant with additives for obs. Elc is not compatible with the older seals especially the injector cups.
Now here is the caveat: others have used elc coolant in their obs and nothing has happened (longest Iíve read was 8yrs).
The final solution? Use the green coolant with additive.
​ DieselDC is offline
post #4 of 6 (permalink) Old 03-18-2018, 06:03 AM
Terminator Nation
The factory said to use on an OBS the low silicate green stuff not the regular green stuff used in autos. About 4 pints of the SCA additive with a complete block flush first. Just draining the radiator does not drain the block.
old man dave is offline
post #5 of 6 (permalink) Old 03-18-2018, 04:34 PM
Bugman's Avatar
Here is a good write up of a coolant flush. The links in it might be bad but the information is still valid.
Bugman is offline
post #6 of 6 (permalink) Old 03-19-2018, 04:57 PM Thread Starter
Looks like the green ford vc 5 is what I will use! Thanks for all the input guys!!
Workman is offline
