TP-38 Turbo Experts. Turbo damage - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 03-17-2018, 02:32 AM Thread Starter
I have very little in and out shaft play on my turbo. Pulled and disassembled it. Looks like a bearing barely wore into the backplate. Other than that truck ran good and turbo internals look good. What would cause this? Can I reuse the backplate and get a rebuild kit and call it good? Also I have a spare center section with no play in it I was going to swap but they are different designs. One has snap rings and one has nothing. Also the shaft on one of them has a recessed section and the other doesn’t. Can someone explain that for me?
File Type: jpeg 0B615EEE-A33B-4F93-802B-CAE6553C5570_1521250251389.jpeg (745.7 KB, 65 views)
File Type: jpeg 0A97CBDC-CE29-40C2-9E5D-944624831950_1521250273495.jpeg (979.2 KB, 59 views)
File Type: jpeg 1133BC2B-58C2-4CE8-B490-BB04BDC062B7_1521250292876.jpeg (611.9 KB, 66 views)
File Type: jpeg 99B500EC-EA64-40F1-B15C-6AC3B921DE2E_1521250315147.jpeg (594.4 KB, 62 views)
DJV333 is offline
post #2 of 6 (permalink) Old 03-17-2018, 03:18 AM
Moderator
Sbluke55's Avatar
Re: TP-38 Turbo Experts. Turbo damage
Pics didn’t work.
01 f-250, Standard
Sbluke55 is offline
post #3 of 6 (permalink) Old 03-17-2018, 04:14 AM Thread Starter
Originally Posted by Sbluke55 View Post
Pics didn’t work.
I see them on my phone. Must be a resolution issue. I’ll see if I can fix it
DJV333 is offline
post #4 of 6 (permalink) Old 03-17-2018, 05:13 PM Thread Starter
I see the pictures on my computer. Anybody?
DJV333 is offline
post #5 of 6 (permalink) Old 03-18-2018, 12:41 AM
Patrick Feeley's Avatar
I can see the pics fine. I haven't done any turbo work, so I'm fairly useless in that department. Maybe try calling Ron's Turbo Service or similar? Cheers!
SOLD: 94 F350 CC DRW PSD, 5 Speed, 4.10 LS, SBC Con-O, Baldwin Filter, Tymar HPX Hose, 3” DP, Bilsteins, $12 AIC, Coolant Filter, Explorer O/H Console, Trans Temp, Boost, and Pyro, Pedestal Mod, Gutted EBPV
Patrick Feeley is offline
post #6 of 6 (permalink) Old 03-18-2018, 05:03 PM
79jasper's Avatar
Keep like parts with like parts.
One is probably TP38, other is from gtp38.
I think what you are seeing is normal. That's a machined boss.
79jasper is offline
