Ford E Locker retrofit? - PowerStrokeNation : Ford Powerstroke Diesel Forum
 1Likes
  • 1 Post By tjctransport
post #1 of 4 (permalink) Old 03-16-2018, 06:02 AM Thread Starter
Ok who has installed the SD E Locker Differential into a sterling 10.25 rear end? Thinking it should fit and at the time replace the rear cover with an aluminum finned Ford one, and drill a hole for the E connection in it. To activate locking is just a 12 volt signal on a switched Relay? Just thinking of options for down the road and was thinking next time Iím at wreckers Iíll have a look to see if any are there.
Thank,
j
Tan white tan 97 ECLB, D60 PMF, RSK SD springs front, airs bags rear, 4:10, intake, FFD 205/30s, DP 4Ē exhaust DIY E-fuel, ZF-5 now
B&W turnover 5th wheel with Anderson hitch.
JCart is online now
post #2 of 4 (permalink) Old 03-16-2018, 12:58 PM
alleged moderator
tjctransport's Avatar
Re: Ford E Locker retrofit?
if i am not mistaken, the superduty E/locker is a 10.5 differential.
Dustybumpers likes this.
tom
tjctransport is offline
post #3 of 4 (permalink) Old 03-16-2018, 02:26 PM Thread Starter
Thatís correct, however I was always led to believe the 10.5 will fit in a 10.25 casing.
j
JCart is online now
post #4 of 4 (permalink) Old 03-20-2018, 05:04 AM Thread Starter
So upon more research on Pirate 4x4, would appear itís doable for sure. At issue guys think initial power requirement is 12 volts to lock up, then after a certain period current reduces to 40 or 50%. Thatís still being discussed, thinking this has to do with electronic traction control and abs possibly. For OBS application thinking 12v would be fine. Will be adding this to the list of to does.
j
JCart is online now
