High pressure oil rail End plug replacement - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 3 (permalink) Old 03-14-2018, 08:02 PM Thread Starter
Ok so I have replaced the large plug at the end of the oil rail on the rear drivers side of the head. I put it in put loctite on it and tightened it up then let it sit overnight. I started it today and it did what I figured it would it just cranked for a good bit refilling the oil rail and then it finally started so I shut it off and added oil to it to get it back up to where it should be I took it for a drive but now it takes more cranks to get it to fire than it used to.
Is there something else I should be checking or adding oil to?
1997 F250 4x4 Extended Cab 7.3L Daily
1997 F350 4x4 Crew Cab 7.3L Work in progress
burton97 is offline
post #2 of 3 (permalink) Old 03-14-2018, 08:22 PM
Bugman's Avatar
Re: High pressure oil rail End plug replacement
Go for a good drive at highway speeds and it should clear all the air out of the system.
Bugman is offline
post #3 of 3 (permalink) Old 03-15-2018, 12:11 AM
^^^^ what Bugman said just need to purge all the air out of the head, Ill take a few miles to do that. Not to worry.
j
Tan white tan 97 ECLB, D60 PMF, RSK SD springs front, airs bags rear, 4:10, intake, FFD 205/30s, DP 4 exhaust DIY E-fuel, ZF-5 now
B&W turnover 5th wheel with Anderson hitch.
JCart is online now
