Fuel leak - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 8 (permalink) Old 03-11-2018, 11:02 PM Thread Starter
rjwarrior88's Avatar
Fuel leak
Hey guys I know it's probably out there but I couldn't find the forum. I have a major fuel leak coming out of the air intake manifold. Would I just need to make a new gasket or would this be a bigger problem than that?
rjwarrior88 is offline
post #2 of 8 (permalink) Old 03-11-2018, 11:10 PM
Bugman's Avatar
Re: Fuel leak
The air intake goes into the tubo and there are no fuel lines attached to it.
Is it spraying or leaking? The filter housing can leak and spray, you also have 2 hoses leaving the fuel filter housing going to the fuel pump and then the fuel pump has metal lines going to the heads.
So just where is yours leaking?
Bugman is online now
post #3 of 8 (permalink) Old 03-12-2018, 12:21 AM Thread Starter
It is spraying fuel out of a bolt in the middle of the intake plenum ( I believe that's it's name). It's on the passenger side near the front of the motor. About 3 or 4 inches behind from where the line goes into the motor.
Is there a way to upload video's?
post #4 of 8 (permalink) Old 03-12-2018, 12:29 AM
alleged moderator
tjctransport's Avatar
Re: Fuel leak
sounds like passenger side head injector supply line is cracked or has a hole rubbed it.
tom
tjctransport is offline
post #5 of 8 (permalink) Old 03-12-2018, 01:35 AM
Bugman's Avatar
Re: Fuel leak
Just take a picture of it.
post #6 of 8 (permalink) Old 03-12-2018, 01:45 AM
Project Shamu
Lt.Dan's Avatar
Re: Fuel leak
So is it in the Middle, or in the Front? If its in the middle, it could be a HPOP line that feeds the heads, if its in the front, it could be the fuel return hose that goes back to the filter housing.
Like they said, pictures will help though.
1996 Cali F350 CCFB, 7.3 PSD, 2wd SAS, w/ 378,000 miles.
New Motor at 352,000, DieselSite Legendary Trans at 356,000 and many more
Lt.Dan is offline
post #7 of 8 (permalink) Old 03-12-2018, 02:40 AM Thread Starter
Okay well after further inspection I realize i am an idiot. It's just fuel line...
post #8 of 8 (permalink) Old 03-12-2018, 05:20 AM
alleged moderator
Re: Fuel leak
don't be too hard on yourself, fuel leaks are a biatch .
and we all make mistakes
tom
