twin beam suspension - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 3 (permalink) Old 03-10-2018, 04:14 PM Thread Starter
ok question is my 96 f-250 4x4 twin beam suspension and famous sag, how do I correct the passenger side camber angle? driver side sits perfect! #beatadeadhorse
Bigboytay89 is offline
post #2 of 3 (permalink) Old 03-10-2018, 05:01 PM
Bugman's Avatar
Re: twin beam suspension
Take it into a alignment shop that has the bushings to fix it.
If that hasn't worked you need to figure out what part is failing and fix that before a alignment.
Bugman is offline
post #3 of 3 (permalink) Old 03-11-2018, 05:28 AM
Best long term fix is replace the TTB with a Dana 60, SD springs and PMF Shackle Reversal Kit. Also install anti sway bars front and rear, Borgeson mid steering shaft and Redhead steering box and you’ll be cheering hard.
j
Tan white tan 97 ECLB, D60 PMF, RSK SD springs front, airs bags rear, 4:10, intake, FFD 205/30s, DP 4” exhaust DIY E-fuel, ZF-5 now
B&W turnover 5th wheel with Anderson hitch.
JCart is offline
