1994.5 PSD fuel filter light on then stalls - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 19 (permalink) Old 03-08-2018, 04:34 AM Thread Starter
PSDiesel's Avatar
Garage
Exclamation 1994.5 PSD fuel filter light on then stalls
I have a 1994.5 PSD around 35-35 mph my fuel filter light will start flickering then it will stay on then eventually stall when it does i took off the fuel filter it had plenty of fuel replaced fuel filter and rebuilt IPR i also cleaned out the fuel bowl and i run PS diesel additive. My truck has 225k on it 5 Spd never really had an issue with it till now. i run maverik fuel aswell Thanks for yalls time
PSDiesel is offline
post #2 of 19 (permalink) Old 03-08-2018, 11:58 AM
PSN intsigator
heavydoc's Avatar
Re: 1994.5 PSD fuel filter light on then stalls
I believe the fuel filter light is your water in fuel light. It either has water in your fuel or it thinks there is have you checked the sensor, or drained the fuel bowl
sig should be here
96 F350 rclb drw 2wd psd (built not bought)
01 Excursion Limited 4wd psd (the wifes ride)
02 F350 cclb drw 4wd psd (the land yacht)
heavydoc is offline
post #3 of 19 (permalink) Old 03-08-2018, 12:53 PM
Native Texan
masakimm's Avatar
Garage
There is a filter light to found it out the hard way. It comes on when it detects suction in the filter housing i believe. when it happens pull ur filter cap it will be low on fuel. I had something in my tank that would block the pickup tube.
Sent from my super awsome outdated new Samsung phone whose 500mA draw hasn't over-overloaded multiple already over rated branch circuits just beyond the kaboom point and caught everything on fire yet.
Upgrades:
masakimm is offline
post #4 of 19 (permalink) Old 03-08-2018, 03:34 PM Thread Starter
PSDiesel's Avatar
Garage
Well the thing is when it died i pulled the filter it had plenty of fuel and the fuel filter light turned off idled smoother when i put it back on it was fine for about 5-7 miles then died out on me again did this on both tanks so i dont believe both tanks can be clogged
PSDiesel is offline
post #5 of 19 (permalink) Old 03-08-2018, 04:48 PM
Native Texan
masakimm's Avatar
Garage
the valve that switches tanks could be clogged and bot letting enough fuel thru to keep the motor going. these trucks should have round 60 psi.
Upgrades:
masakimm is offline
post #6 of 19 (permalink) Old 03-08-2018, 06:26 PM
79jasper's Avatar
This is exactly what I had happen. Both showerheads disintegrated. Lol
Changed the lift pump twice trying to figure it out.
79jasper is offline
post #7 of 19 (permalink) Old 03-10-2018, 12:09 AM Thread Starter
PSDiesel's Avatar
Garage
i just noticed that when it was cranking over my oil pressure never moved im starting to think its a faulty IPR
PSDiesel is offline
post #8 of 19 (permalink) Old 03-10-2018, 12:19 AM
Native Texan
masakimm's Avatar
Garage
the ipr has nothing to do with the gauge on the dash. it shows the pressure of the low pressure system. and would have nothing to do with the fuel filter light either. the system getting plugged from pieces of the shower head pickup from the tank is very common. I have changed mine to just straight pipe but forgot to put a screen on the bottom so had mine getting clogged by some gelling in the tank. put some stainless screen on the end and no more problems.
Upgrades:
masakimm is offline
post #9 of 19 (permalink) Old 03-10-2018, 12:26 AM Thread Starter
PSDiesel's Avatar
Garage
it started doing it with 3/4 of a tank so it had plenty of fuel
PSDiesel is offline
post #10 of 19 (permalink) Old 03-10-2018, 12:36 AM
Native Texan
masakimm's Avatar
Garage
yes but if the plastic got sucked into the pick up tube it will restrict the fuel flow to the filter and injector system causing the filter light to come on and engine to die. My front tank currently has a problem that causes my truck to die so I am running off my custom rear tank till I can fix my front tank.
Upgrades:
masakimm is offline
