Need new pcm - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 9 (permalink) Old 03-03-2018, 09:44 PM Thread Starter
Need new pcm
hey guys so my trucks a 97 7.3 auto and im pretty sure i need a new pcm, the overdrive pin isnt getting power and i checked and the button isnt shorted. I installed a ts 6 position chip on my truck and thats when the problem of the Overdrive staying off happened and it will go on once in a while but if i hit the brake pedal overdrive goes off again. So is anyone have a pcm for my truck i could buy. I cant find any at the junkyard. Im located in Vancouver bc canada.
smashman511 is offline
post #2 of 9 (permalink) Old 03-03-2018, 09:49 PM
College Student
Re: Need new pcm
Did you try removing the chip to see if it works without it. If it worked fine without it, then stopped once the chip was put it, its probably related to the chip then.
95 Auto. 4.10 gears. SCLB. Stock besides Baby Swamps Injectors and TS-6 chip with swamps tunes. AFE MaxFlow. Glowshift trans, pyro, and boost. 6.0 IC KC TP38R. Converted EBPV to exhaust brake.
Cumminsdurastroke is offline
post #3 of 9 (permalink) Old 03-03-2018, 09:53 PM Thread Starter
Re: Need new pcm
Yea i took the chip out and tested it out. same problem.
post #4 of 9 (permalink) Old 03-03-2018, 09:55 PM Thread Starter
Re: Need new pcm
when i took the pcm out to put the chip in, i guess the previous owner had a chip in it before and took it out because it was already sanded down. However i decided to go over it again stupidly. So i think i did the trick on it haha
post #5 of 9 (permalink) Old 03-04-2018, 01:51 AM
Re: Need new pcm
The brake light circuit should NOT downshift it. It will disengage the torque converter lock, however. Are you sure it's actually downshifting, and not just unlocking the TC?
madpogue is offline
post #6 of 9 (permalink) Old 03-06-2018, 03:48 PM Thread Starter
Re: Need new pcm
it kicks it out of overdrive, so yes it will downshift it.
post #7 of 9 (permalink) Old 03-08-2018, 02:18 AM
Re: Need new pcm
Does the OD-OFF light go on when this happens?
madpogue is offline
post #8 of 9 (permalink) Old 03-14-2018, 03:18 PM Thread Starter
Re: Need new pcm
Fixed the problem. Got a new pcm off a old guy for 60$. thanks guys
post #9 of 9 (permalink) Old 03-15-2018, 04:26 PM
Re: Need new pcm
Good find..... glad it worked out for you. You might consider re-tinning the connections on the circuit board plug in socket then you’ll have a spare PCM, with the dough you saved. An electronics place could easily do this if you don’t have the gear. Also ensure you brake lights and 3 brake light are in good working order as well as trailer brake lights too, these can mess with TC unlocking or not locking up.
Cheers,
j
Tan white tan 97 ECLB, D60 PMF, RSK SD springs front, airs bags rear, 4:10, intake, FFD 205/30s, DP 4” exhaust DIY E-fuel, ZF-5 now
B&W turnover 5th wheel with Anderson hitch.
JCart is offline
