1997 f-350 exhaust manifold replacement - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 8 (permalink) Old 03-01-2018, 09:02 PM Thread Starter
Howdy, new to the forum a have a buddy with a driver side manifold leaking as well as the up pipe gasket to the manifold just looking for some pointers, tips, and hopefully pictures. Iíve done manifolds on several other vehicles, have yet to do one on these obs trucks. Looks like Iíll need to remove the wheel and inner fender to get at it. Iíve read most people cut the heads off the bolts pull the manifold and back the studs out with vice grips or a stud removal tool, is this the best way? or will it require the nut and welder trick any help will much be appreciated!
Darien111White is offline
post #2 of 8 (permalink) Old 03-01-2018, 09:03 PM Thread Starter
Oh bye this is 7.3 turbo truck with LOTS of rust.
post #3 of 8 (permalink) Old 03-01-2018, 09:46 PM Thread Starter
I donít even know got to edit my post sheesh Iím sorry in advance lol
post #4 of 8 (permalink) Old 03-02-2018, 01:01 AM
Patrick Feeley's Avatar
Re: 1997 f-350 exhaust manifold replacement
From the factory, they did not have gaskets at the manifold-to-head joints. Gaskets are available though. I've never had to do them on my truck, so I'm no help on the procedure! Cheers!
SOLD: 94 F350 CC DRW PSD, 5 Speed, 4.10 LS, SBC Con-O, Baldwin Filter, Tymar HPX Hose, 3Ē DP, Bilsteins, $12 AIC, Coolant Filter, Explorer O/H Console, Trans Temp, Boost, and Pyro, Pedestal Mod, Gutted EBPV
Patrick Feeley is offline
post #5 of 8 (permalink) Old 03-04-2018, 01:29 AM
Akita91's Avatar
as i read it online and based on my f super duty 97,i would cut em with cutoff tool flush to manifold(airchisel bolt heads later if reusing manifold) and vise grip the rest.u gotta take off wheel and sawzall some fender to reach right and left bolts.i would do this if i wasnt tired of fighting uppipes in 4 days it seems easy job
Akita91 is offline
post #6 of 8 (permalink) Old 03-04-2018, 05:52 AM Thread Starter
Originally Posted by Akita91 View Post
as i read it online and based on my f super duty 97,i would cut em with cutoff tool flush to manifold(airchisel bolt heads later if reusing manifold) and vise grip the rest.u gotta take off wheel and sawzall some fender to reach right and left bolts.i would do this if i wasnt tired of fighting uppipes in 4 days <img src="https://powerstrokenation.com/forums/images/smilies/biggrin.gif" border="0" alt="" title="Big Grin" class="inlineimg" /> it seems easy job
. Thatís what Iím doing used a cut off wheel on the heads of the bolts gonna hit em with pb and map torch and hopefully twist em out with vice grips or a stud extractor can I in bolt and remove the fender liner easily or is all that junk like fuse block and #### attached to it?
post #7 of 8 (permalink) Old 03-04-2018, 05:54 AM Thread Starter
Also Iím not using gaskets new manifolds flush to the heads and I got new flange gasket to the up pipes
post #8 of 8 (permalink) Old 03-04-2018, 03:13 PM
excavator's Avatar
This is what i did on my 96 replacing rusted out driver side manifold.
Bolts were rusted to manifold and were not moving.
I took an air chisel to the manifold and cracked it into pieces and it will brake away from bolts.
Then vice grips took bolts out of head fairly easy
96 F250 XLT 4x4 210000 miles Dana 60, Baby Swamped,Tony Wildman tunes,AutoMeter Pyro Boost Trans ,DPP downpipe,Tymar intake BTS TRANS
e99 f350 cc/lb drw php hydra plus Tony Wildman tune
excavator is offline
