97 PSD 7.3 Died Now No Start - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 9 (permalink) Old 02-26-2018, 01:36 PM Thread Starter
Hey guys I'm new to this forum and to diesels all together but I inherited my father's 97 7.3 after he passed away and I'm trying to fix her up and I've run into a problem.
What I do know...
Truck sat for a few years but was running.
I had it started about a month ago letting it run a while and it died out of nowhere and won't start back up.
Batteries are new, icp sensor is new, camshaft position sensor is new.
When I try to crank the motor, white smoke billows from the exhaust so I believe that tells me the injectors are firing and that I'm getting fuel.
I did a voltage drop test and my glow plug relay tested with spec as did all of my glow plugs.
I checked the oil level in the HPOP and it's nearly full.
I'm stumped!!
CamoX413 is offline
post #2 of 9 (permalink) Old 02-26-2018, 01:39 PM Thread Starter
Also, after about 30 seconds of cranking I get this strange loud clicking noise coming from somewhere in the engine bay. I don't know if that's related but figured I'd throw it out there.
CamoX413 is offline
post #3 of 9 (permalink) Old 02-27-2018, 01:43 PM Thread Starter
Is this forum dead??
CamoX413 is offline
post #4 of 9 (permalink) Old 02-27-2018, 02:36 PM
Re: 97 PSD 7.3 Died Now No Start
I think you have a bad glow plug relay, mine was bad even though the the time I tested it, it tested good. Could also be a bad harness connection, check the plugs where the main harness connects to the valve cover harnesses, there are four of them. Carefully unplug them and check for softness/burnt/corroded connection. If you work on the harness or the glow plug relay make sure you disconnect both negative battery cables. I had to splice in a new main harness connector on mine.
96 F350 CCLB SRW, tymar, 4in turbo back, beans 6 pos, stock inj, banks intercooler, zf5 w/ 4.10s, 37gal rear tank, 285s. Tows horses around KY.
kypatriot is offline
post #5 of 9 (permalink) Old 02-27-2018, 03:33 PM
It would help to know more precisely where the clicking sound is coming from. If it is indeed the GPR, it may be defective as mentioned, or you may have a main power / connection issue. Weak batteries, weak battery/ground connections, etc.
madpogue is offline
post #6 of 9 (permalink) Old 02-27-2018, 07:13 PM
RustbeltJohnny
Rustbeltjohnny's Avatar
Garage
That sounds like a glow plug relay to me. I can't think of any relay that makes a "loud clicking" sound besides that one relay. But I also don't see why that would shut down the motor after running. So I also would shoot you in the direction of your harness. Check exactly what was said above and get a nice digital volt meter. Also review through the harness and make sure your wiring isn't bad.
Get out your pooper scoopers, cuz these suckas are talkin ####.
Rustbeltjohnny is offline
post #7 of 9 (permalink) Old 02-27-2018, 08:23 PM Thread Starter
My batteries are brand new.
I went ahead and ordered a new glow plug relay to see if that helps.
Thing I do notice is that the battery light in the cab is on and I've checked both batteries with my voltmeter and they're both testing good and I charge them last night just to be certain.
The clicking noise as I'm cranking sounds like it's coming from somewhere near the fuel bowl.
I went ahead and change the fuel filter this morning and the fuel bowl was nearly empty but after cranking for a little bit it was about half full when I rechecked it.
I'll look at the connections right now
CamoX413 is offline
post #8 of 9 (permalink) Old 02-27-2018, 09:06 PM Thread Starter
I can't seem to find any issues with the harness and I've checked every fuse in the vehicle. They were all good.
CamoX413 is offline
post #9 of 9 (permalink) Old 02-28-2018, 01:21 AM
Ryan Goodnight's Avatar
Any engine light or codes? My glow plug relay was clicking at times when I was having problems with power coming to both glow plug banks. After 20+ hours of pulling valve covers, changing glow plugs,Valve cover gaskets and glow plug relay, Ohming wires and conncections, all which were a waste of time. I pulled the PCM today in plans of mailing it for testin and I had my Banks Chip half way unplugged. Bondage’s the chip in place with duct tape and will be driving the truck next few days to test it. But I was having my glow plug relay clicking when it wasn’t getting enough power.
Ryan Goodnight is offline
