HPOP going bad? - PowerStrokeNation : Ford Powerstroke Diesel Forum
 1Likes
  • 1 Post By Patrick Feeley
post #1 of 5 (permalink) Old 02-25-2018, 03:47 PM Thread Starter
HPOP going bad?
Here are the syptoms on my 97 OBS 7.3 with 213,xxx. Oil residue in the valley toward the front and dry toward the back, slight drip coming down the front of the engine, driving it today felt like it was running on half power, sluggish of the line, rough idle, etc... My thoughts are the HPOP is on its way out and itís only running on 4 cylinders but Iím no expert... Any insight would be much appreciated!
Futchgator is offline
post #2 of 5 (permalink) Old 02-25-2018, 04:27 PM
Patrick Feeley's Avatar
Re: HPOP going bad?
Is the CEL illuminated? Oil level good? Is it oil residue or a puddle? The HPOPs are fairly stout. You can try disconnecting each valvecover harness connection while its running and see what the change is. No change, the two cylinders associated with that connection have a problem. If it changes they should be OK electrically. At any rate, inspect the valvecover gasket pins and harness connector pins for evidence of melting or burning. Cheers!
aussamdad likes this.
SOLD: 94 F350 CC DRW PSD, 5 Speed, 4.10 LS, SBC Con-O, Baldwin Filter, Tymar HPX Hose, 3Ē DP, Bilsteins, $12 AIC, Coolant Filter, Explorer O/H Console, Trans Temp, Boost, and Pyro, Pedestal Mod, Gutted EBPV
Patrick Feeley is offline
post #3 of 5 (permalink) Old 02-25-2018, 04:41 PM Thread Starter
No CEL. There some oil near the pulleys... Iím wondering it may be one of the seals/ fittings going bad
File Type: jpeg 9A476780-B71C-44D2-B082-621894DF92B0_1519576816436.jpeg (845.9 KB, 29 views)
post #4 of 5 (permalink) Old 02-25-2018, 04:58 PM Thread Starter
There is some pooling in the valley at the base of the HPOP... Photo attached
File Type: jpeg 419AF903-4C15-4ABC-91D3-43E7D2B37C46_1519577886849.jpeg (1.17 MB, 41 views)
post #5 of 5 (permalink) Old 03-02-2018, 02:32 PM
Re: HPOP going bad?
If you are running on 4 cylinders, then follow Patrick's advise...harness, pins that is usually the issue. You may have some oil leaks...clean them up and then check again to ID the leak.
1996 F350 Crewcab lb 2wd auto, tommylift, now over 451k, 355k 3/31/15
1991 F250 Xtracab lb 2wd auto, sold again! Driveline and chassis is under a '65 F350 cab
1965 F100 styleside, power brakes, front discs, 390 all the goodies
2015 F250 CCSB 2wd gasser auto
2008 Mustang WIP, warriors in pink, wife's
2009 Focus, son's
aussamdad is offline
