Transmission Dipstick Tube pinhole leak - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 02-24-2018, 07:28 PM Thread Starter
Question Transmission Dipstick Tube pinhole leak
1997 F250 HD XLT 7.3L Diesel 4X4, with E40D transmission. While getting a transmission flush yesterday, my mechanic noticed that the trans fill tube had a hole in it from rubbing against the exhaust manifold. From doing a search here, trans fill tubes have been covered a bit, but the posts are pretty old, and I'm not having much luck finding a replacement tube online, much less a correct part number for my specific truck. It seems the dealer-based online sources don't list it in their exploded view parts inventory at all, or it's impossible to determine whether the part I'm looking at from other sources is the exact one for my truck (seem to find a lot of E40D tubes on amazon and ebay, but none that list my specific vehicle in their compatibility chart).
I can swing by the dealer and ask them, but I'm expecting if they do still have them, they're going to charge a lot. I can look at the junkyard, but these trucks are getting awfully rare. Worse case scenario, I can JB Weld the hole and fit some sort of guard between the tube and the exhaust to keep it from happening again.
****LAST MINUTE UPDATE: So, silly me, I just dug out my factory shop manual, got a part# out of it (7A228), looked it up on Amazon, and it came back with this one: F81Z-7A228-AA, however, it only lists compatibility with "'99-'05 F-250 F-350 F-450 F-550 Super Duty Excursions". Can someone tell me if this is indeed the correct part for my application?
Darren Murdock is offline
post #2 of 4 (permalink) Old 02-24-2018, 08:04 PM
Native Texan
masakimm's Avatar
Garage
Re: Transmission Dipstick Tube pinhole leak
Well I looked back thru my research when I had to replace my 97 transmission dip stick and have the part number for dipstick and part number for short tube at transmission but never could find a part number for the tube its self. best bet may be local salvage yard. I know it took me for ever to find dipstick online as its been discontinued. The part u list may or may not work but it is for gas engines not 7.3l to.
Upgrades:
masakimm is offline
post #3 of 4 (permalink) Old 02-24-2018, 08:57 PM Thread Starter
Thanks, masakimm. I'm going to try running by the dealership to see if I can get an accurate part # from them.
post #4 of 4 (permalink) Old 02-26-2018, 11:17 PM Thread Starter
Ran by the dealer, and using my VIN#, they came up with F5TZ-7A228-AA as the exact part number for my truck's configuration. Now to see if I can find one online...
