96 ZF5-how much ATF for a top fill - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 02-22-2018, 02:43 PM Thread Starter
Ok, had a hard time removing the side fill plug. So I removed the shifter and will fill it from the top (after defeating a stripped allen head bolt -what were they think using allen heads).
Anyway, is five quarts through the top too much? 6? 7? I know it is suposed to take about 3.5 from the side, but heard it will quiet it down to overfill from the top.
I am using mobil 1 full synthetic atf.
Any concerns with overfilling? Overpressurization? Seal leaks? It would be nice to dampen the rollover noise some.
96 F350 CCLB SRW, tymar, 4in turbo back, beans 6 pos, stock inj, banks intercooler, zf5 w/ 4.10s, 37gal rear tank, 285s. Tows horses around KY.
kypatriot is offline
post #2 of 6 (permalink) Old 02-22-2018, 03:52 PM
Trust me, I got this...
Cummins Junkie's Avatar
Garage
Re: 96 ZF5-how much ATF for a top fill
4 qts is plenty. I wouldn't overfill it; they put that spec there for a reason.
Sent from my SM-J320V using Tapatalk
Shoulda bought a Cummins.
1997 F250 7.3L XLT, 4x4, 5spd, 315K, TS chip, BD Turbo-Thruster II, Donaldson 6637 filter, 4" straight piped dual exit SOLD
1995 F350 CCLB 6.0L WIP
Pain is inevitable. Suffering is optional.
Cummins Junkie is offline
post #3 of 6 (permalink) Old 02-22-2018, 04:04 PM Thread Starter
Thats kinda what I was thinking, though the spec could have come from where they needed to put the fill plug. I know some guys have put as much as 8 qts in. It is supposed to quiet it down but I have never heard feedback from the guys who put extra in.
I dont get why the fill plugs are so hard to remove. I was flexing a two foot breaker bar and with the aluminum case just decided to quit. The spec on that plug is only 44ftlb!
post #4 of 6 (permalink) Old 02-22-2018, 04:33 PM
Agreed 4 quarts is the number as I recall. Mobile 1 full synthetic is good, however I have used Redline MTF (which I think is full synthetic too) with excellent results. In fact it resolved a problem with 2nd gear synchroes and extended need for rebuild for alt least a year. My ZF rebuilder couldn’t believe the difference and he used it afterwards on his rebuilds.
j
Tan white tan 97 ECLB, D60 PMF, RSK SD springs front, airs bags rear, 4:10s 37 Toyo R/Ts intake, FFD 205/30s, DP 4 exhaust DIY E-fuel, ZF-5 now
lights: VisionX & HID projectors in headlights.
JCart is offline
post #5 of 6 (permalink) Old 02-22-2018, 06:55 PM
It's 3.2 quarts at the fill plug. So four quarts is a slight overfill, and I've read varying opinions about that. I sure wouldn't go with any more.
madpogue is offline
post #6 of 6 (permalink) Old 02-22-2018, 10:43 PM Thread Starter
Ok so here is what I did. I put in 5 quarts of mobil1 and a half quart of lucas synthetic oil stabilizer. It is much much quieter on the rollover noise, and shifts better than ever, though it has always shifted pretty good. I took it for a test spin, nothing of note so far. It has a tiny seep were the case halves come together (has had that awhile) and I will watch that to see if it gets worse due to the overfill. Its a huge case so there is still plenty of air in there. Ill report back if anything bad happens lol but so far a big improvement on noise.
