97 E4OD and tach problems - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 02-22-2018, 02:31 PM Thread Starter
redkw's Avatar
Hey all, first post, my 1997 f350 crew cab long bed 2wd dually is having a hardshift problem. I have a map/baro code but my map sensor itself isn't the problem and I've never seen a barometer. Also my tach works only half the time. I was told i should track down that code but its either too cold or raining and my truck doesn't fit in the garage. Any help would be appreciated.
redkw is offline
post #2 of 4 (permalink) Old 02-22-2018, 06:57 PM
Re: 97 E4OD and tach problems
The BARO sensor is in the cab, under the dash.
The tach gets its signal from the PCM, which uses a signal from the CPS. But if the CPS is inop, the engine shouldn't run. That's a head-scratcher.
madpogue is offline
post #3 of 4 (permalink) Old 02-22-2018, 07:13 PM Thread Starter
redkw's Avatar
Well now that you mention it sometimes it has a cps code too
1997 F350 XLT CCLB Dually 7.3 Powerstroke Automatic 2wd 3 inch straight thru muffler to 4 to 5 to 7 inch miter cut stacks
1997 F350 XLT CCLB SRW 7.3 Powerstroke Automatic 4x4 3 1/2 inch straight pipe
redkw is offline
post #4 of 4 (permalink) Old 02-23-2018, 12:51 PM Thread Starter
redkw's Avatar
It must be my tach because my tuner always gets the rpms in the data stream. Sometimes i have a camshaft pos sensor
redkw is offline
