nuetral saftey - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 12 (permalink) Old 01-16-2008, 03:01 PM Thread Starter
Hog Whisperer
tater97's Avatar
nuetral saftey
How does the switch come off? is there a pin or a lock nut? tater
1997 Ext. 4x4 5 spd, All green finally!,Beans 1's, Tymar, 3"-4" DP Exhaust, Shimmed FPr 1.0 Turbo,6Pos TONY WILDMAN burn. Okiecooler, ccv mod, SouthBend ConFE,superduty spring packs,17* hpop
Number19
tater97 is offline
post #2 of 12 (permalink) Old 01-16-2008, 04:31 PM
racehauler's Avatar
Re: nuetral saftey
Tater how's it goin?
I haven't the slightest clue.
His truck is a 5 speed though for all the poeple that may have the knowledge.
Eric
96 F-350 CC Dually
300/100% B codes, Stealth dual pumps, H2E, BTS trans, ARP head studs, Comp 910 valve springs, Tyrant Tunes
6.0 IC, Fuelab electric fuel pump, NAPA 6637 air filter, ITP Overboost Annihilator, AeroTurbine 4040XL
racehauler is offline
post #3 of 12 (permalink) Old 01-16-2008, 05:21 PM Thread Starter
Hog Whisperer
tater97's Avatar
Re: nuetral saftey
Well i figgured it out. There's a clip on the bottom at the back of it, pull down on it and pull the saftey forward that will free it forward and to spin. spin the top around to the 6:00 position. theres a clip there. and if you've seen that clip before will know how to take it off. I had never seen it before so I broke it and slid the old saftey off. then do the reverse except for the breaking part.Tater
Number19
tater97 is offline
post #4 of 12 (permalink) Old 01-16-2008, 05:53 PM
racehauler's Avatar
Re: nuetral saftey
I'm trying to visualize this but can't figure out what area of the truck you are talking about. Is this on your truck or is this on someone else's auto?
If it's on your truck what area are you working on? The clutch pedal?
Eric
96 F-350 CC Dually
post #5 of 12 (permalink) Old 01-16-2008, 05:59 PM Thread Starter
Hog Whisperer
tater97's Avatar
Re: nuetral saftey
Yeah its my truck.under the dash. Look at the clutch pedal. Follow it up and over to the right and above the fuel pedal is a rod going thru the firewall. The switch is on that rod.Gotcha good and confused? Tater
Number19
tater97 is offline
post #6 of 12 (permalink) Old 01-16-2008, 06:02 PM
racehauler's Avatar
Re: nuetral saftey
Ok. See I don't have any of those clutch pedal thingamabobs or anything like that on my truck so I was really lost as to what you were describing. Sounded somewhat like you were working on an auto, but I knew you had a manual trans.
Eric
96 F-350 CC Dually
post #7 of 12 (permalink) Old 01-16-2008, 06:06 PM Thread Starter
Hog Whisperer
tater97's Avatar
Re: nuetral saftey
Wow I started by asking a question and then answered my own post. Maybe I shouldnt have asked?
Number19
tater97 is offline
post #8 of 12 (permalink) Old 01-16-2008, 06:16 PM
racehauler's Avatar
Re: nuetral saftey
Eric
96 F-350 CC Dually
post #9 of 12 (permalink) Old 01-16-2008, 10:04 PM Thread Starter
Hog Whisperer
tater97's Avatar
Re: nuetral saftey
And then when you do all that and it fails like it just did for me you cut the hot wire and straight wire it so it will start with out the clutch...Quite a conversation with my self.
Number19
tater97 is offline
post #10 of 12 (permalink) Old 01-17-2008, 12:39 AM
racehauler's Avatar
Re: nuetral saftey
Eric
96 F-350 CC Dually
