Transfer case issue - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 2 (permalink) Old 01-15-2008, 11:03 PM Thread Starter
Underfunded
moonshiner's Avatar
Send a message via AIM to moonshiner
Transfer case issue
Sometimes when i have my trasfer case enaged in 4-low it will pop out and shift into neutral.
I have no idea what model of case i have but it is a manual shift.
What do i do?
1996 F350: 4.10's Detroit Locked Front/Rear, Rampage Chip, SD/Racor E-Fuel, Adrenaline, 160cc's, Bell SS/66 Turbo, SD CAC, 315/75/16's Fierce M/Ts, 6" Lift, 6ft Traction Bars, 5" Stacks.
2007 Harley FXSTB: Bassani Prostreet Pipes, Terry Comp tuner, V&H Air Cleaner
2008 Honda Ridgeline RTX
2010 VW Jetta 2.5
SEMPER FI - USMC LT.
moonshiner is offline
post #2 of 2 (permalink) Old 01-16-2008, 12:52 AM
X Racer
Racer X's Avatar
Re: Transfer case issue
You can check the linkage for bends or bad grommets. Also the shift lever can be adjusted some.
Contact Racer X USA for Fully Custom built transmissions, Torque Converters & Valve Bodies.
Racer X is offline
