DRL - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 15 (permalink) Old 09-05-2017, 12:16 AM Thread Starter
DRL
I have electrical feedback to DRL module. Heats up module when ignition is off. Appears to be feedback to ground. New Module, New Headlight Switch, checked Multi Function Switch. Any suggestions. Thanks
Harwen is offline
post #2 of 15 (permalink) Old 09-05-2017, 01:08 AM
alleged moderator
tjctransport's Avatar
Re: DRL
welcome to PSN.
are you in an area where DRL's are required? if not, you can just unplug the relay and that will disable the DRL's
tom
tjctransport is offline
post #3 of 15 (permalink) Old 09-05-2017, 03:12 AM
Re: DRL
^^^^^ That will also probably disable the headlights. Remember, the non-DRL trucks have a jumper in the DRL relay connector; the circuit isn't just left open. No access to my EVTM, so I don't know what that jumper jumps, but you'd have to either get that jumper, or jump the same terminals it jumps, in order to decommission the DRLs.
madpogue is offline
post #4 of 15 (permalink) Old 09-05-2017, 03:20 AM
Patrick Feeley's Avatar
Re: DRL
I can't find a relay that would be specific to the DRLs in my EVTM. To disable the DRLs, you would need the "Jumper Plug" that plugs into the harness in place of the module. To the OP, is the parking brake switch closing/opening as it should? Is your Brake Warning light working? I've attached the DRL diagram from the 1997 EVTM for reference and troubleshooting. Cheers!
Patrick Feeley is offline
post #5 of 15 (permalink) Old 09-05-2017, 03:36 AM
79jasper's Avatar
Re: DRL
Maybe you can make your own.
79jasper is offline
post #6 of 15 (permalink) Old 09-05-2017, 04:00 AM Thread Starter
Re: DRL
Thanks Everyone. The parking brake switch is working properly. Thanks for the diagram. Any other suggestions are welcome.
Harwen is offline
post #7 of 15 (permalink) Old 09-05-2017, 05:35 AM
79jasper's Avatar
Re: DRL
Is it draining your batteries?
You could do a parasitic draw test.
79jasper is offline
post #8 of 15 (permalink) Old 09-05-2017, 11:48 AM
alleged moderator
Re: DRL
good to know. i have never messed with pickup DRL's, only large trucks. on the big trucks it is as simple as unplugging the relay.
tom
post #9 of 15 (permalink) Old 09-05-2017, 08:10 PM
Terminator Nation
Re: DRL
The headlights will work without the DRL Module plugged in. The DRL supplies pulsed voltage to the high beams when the truck is running.
The DRL headlight circuit is separate from the normal hi/lo circuit feeding the headlights. However, the high beam indicator light and the parking brake switch circuits also go through the DRL plug (module). The jumpers are installed to restore those functions.
Using ETVM pages 97-1, 97-2 and 60-6 (for diesel)
At the DRL plug:
Pin 1 GY/W High Beam Indicator light
Pin 2 Not Used
Pin 3 P/O Power Hot in Run
Pin 4 LG/R Parking Brake Switch
Pin 5 P/W Brake Warning Indicator
Pin 6 R/BK Low Beam Headlights
Pin 7 BK/O Power Hot at All Times
Pin 8 High Beam Headlights
Jumper wire 12 LG/BK pin 8 to wire 932 GY/W pin 1 for High Beam Indicator Light in dash.
Jumper wire 977 P/W pin 5 to wire 162 LG/R pin 4 for Parking Brake Switch.
old man dave is offline
post #10 of 15 (permalink) Old 09-05-2017, 09:38 PM
POWERSTROKEMIKE
Re: DRL
i wish my truck had them has anyone ever modified a truck that didn't have them to have them
powerstrokemike is offline
