Weird popping noise from rear - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 08-31-2017, 07:40 PM Thread Starter
96WhiteRclb's Avatar
Very strange situation. I've noticed now after it rains while taking a right hand turn or pulling into driveways there is a loud pop coming from the rear of the truck. It only does it during and after rain. Believing the rain is lubing something allowing it to move. I have crawled under and noticed the rear sway bar can be moved side to side about a inch or two and coming into contact with a ear on the drive side of the axle. Anyone seen this before
Sent from my SAMSUNG-SM-G935A using Tapatalk
96WhiteRclb is offline
post #2 of 7 (permalink) Old 08-31-2017, 08:03 PM
Bugman's Avatar
Re: Weird popping noise from rear
Do you have a limited slip rear end?
Bugman is offline
post #3 of 7 (permalink) Old 08-31-2017, 08:14 PM Thread Starter
No. I don't believe I do. You can't feel it while you driving. Only able to hear it like something is hitting.
post #4 of 7 (permalink) Old 08-31-2017, 08:38 PM
Bugman's Avatar
Look on the sticker on the drivers side door jamb and check the axle code on this site to find out.
What rear end ratio is in my Ford , do I have positraction? - Drivetrain
Bugman is offline
post #5 of 7 (permalink) Old 08-31-2017, 08:43 PM Thread Starter
39- conventional non-positraction differential
post #6 of 7 (permalink) Old 09-01-2017, 03:02 PM Thread Starter
I don't believe it's a issue with the rear. If it did it all the time I would be leaning more towards that. I notice it alot while pulling into a gas station and the suspension articulates because of the uphill entrance
post #7 of 7 (permalink) Old 09-01-2017, 03:25 PM
Bugman's Avatar
Perhaps have a friend walk behind your truck and look underneath it when this is happening to see if they can see anything twisting causing it.
I once had a mechanic ride on some running boards as I drove down the road to figure something out on a company truck.
Bugman is offline
