Someone take a look at this! - PowerStrokeNation : Ford Powerstroke Diesel Forum
 1Likes
post #1 of 11 (permalink) Old 08-31-2017, 06:23 PM Thread Starter
96WhiteRclb's Avatar
Recently bought a 96 zf5 truck and while installing the new downpipe I noticed a pair of vice grips on what I'm think in the ebpv actuator. Has anyone seen this before?
File Type: jpg 15042000625991775931848_1504200111478.jpg (14.1 KB, 64 views)
96WhiteRclb is offline
post #2 of 11 (permalink) Old 08-31-2017, 06:29 PM
EA - Eggfarts Anonymous!
Turd-250's Avatar
Re: Someone take a look at this!
hahaha! that pic is kinda hard to see as an atachment, but i guess somebody had a little bit of trouble and got tired of messing with it lol :p if you remove it and you can't build much boost then you'll know
by the way, welcome to the forum!
"Farts are like a good bourbon, add a small touch of water to bring out the excellence."
Turd-250 is offline
post #3 of 11 (permalink) Old 08-31-2017, 06:38 PM
Bugman's Avatar
Instead of wiring it open they used a more expensive way to take care of it.
Bugman is offline
post #4 of 11 (permalink) Old 08-31-2017, 06:43 PM Thread Starter
So im guessing the way the vise grips are wedged against the intake plenum its keeping the valve open?
post #5 of 11 (permalink) Old 08-31-2017, 06:48 PM
Bugman's Avatar
Yep, odds are that a previous owner had a problem with it and used the vicegrips and then forgot about them.
You can wire it open or if you pull the turbo you can gut it and be done with it. It really isn't needed.
Bugman is offline
post #6 of 11 (permalink) Old 08-31-2017, 07:34 PM Thread Starter
Haven't notice it closing or loss of power. I do notice it's a little sluggish while it's cold. But when she's warm she runs damn good
Sent from my SAMSUNG-SM-G935A using Tapatalk
post #7 of 11 (permalink) Old 08-31-2017, 07:43 PM
Are those genuine Motorcraft vice grips? If not, get them outta there!!!!!! ROFL!!!!!!!!
Turd-250 likes this.
dragondave is offline
post #8 of 11 (permalink) Old 08-31-2017, 11:50 PM Thread Starter
I've noticed that it's still plugged into the harness. So would that mean it still tries to activate?
post #9 of 11 (permalink) Old 09-02-2017, 04:13 PM
Yes... my guess is was pissin the previous owner off coming on all the time (or too much for them) so they "locked" it open with the vise grips, novel way to keep'er open. My '96 cycles too often for my liking even when it's not that cold out and acts like an engine retarder. I'm thinking it's an early 96 engine build and the stock programming parameters are an early version and updates PCM versions don't trigger as much (or trigger in colder temps). If you plan on keeping it I'd gut the pedistal and the flap out of the exhaust flow. Or an alternative is to put in a manual over ride switch and use as an exhaust brake as it's a ZF5. Just be careful not to built too much back pressure using as an engine retarder as it could float your valves.... e.g. Big load steep grade flap activated and rpms near redline.
jrc
Tan white tan 97 ECLB, D60 PMF, RSK SD springs front, airs bags rear, 4:10s 37 Toyo R/Ts intake, FFD 205/30s, DP 4 exhaust DIY E-fuel, ZF-5 now
lights: VisionX & HID projectors in headlights.
JCart is offline
post #10 of 11 (permalink) Old 09-02-2017, 11:49 PM
Terminator Nation
Actually, it should be Ford "Rotunda" tools.
old man dave is offline
