PCM replacement (where to buy) - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 08-29-2017, 04:09 PM Thread Starter
95 F250 2001 F450
Powerstrokebuff's Avatar
Can anyone tell me the best place on line to get a reliable PCM replacement for my 95, that you have had good luck with. Thanks
Powerstrokebuff is offline
post #2 of 4 (permalink) Old 08-29-2017, 05:58 PM
Re: PCM replacement (where to buy)
What I have done is search for somebody parting out a 94.5-97 7.3. Any dpc 202 will work for the autos and any dpc 203 for manuals
jrdonicht is offline
post #3 of 4 (permalink) Old 08-30-2017, 01:19 AM
Patrick Feeley's Avatar
I got one for my 94 from RockAuto ($115 plus refundable core). You'll need a DPC-202 PCM for an automatic trans or a DPC-203 for a 5-speed truck as previously mentioned by jrdonicht. Cheers!
Patrick Feeley is offline
post #4 of 4 (permalink) Old 08-30-2017, 03:29 AM
I would only get a reman/core charge PCM if you _know_ your PCM is bad. If you don't you could be paying, effectively, to reman a perfectly good PCM. I would put that money into a PCM from a part-out truck as mentioned. If the truck still doesn't start, you still have a problem, but once that's solved, your money has gone into having a spare on hand for the future.
madpogue is offline
