96 f350 Shaking Problems - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 08-27-2017, 11:54 PM Thread Starter
ct_domv
Bought a 96 f350 awhile back and doing a full restoration on the truck. Just finished painting the frame. Took the truck for a drive and when i slow down into the low gear, the whole truck shakes. I pulled my foot off the brake to see if it was my rotors and its not. When i get to a higher speed the truck doesnt shake, only when its in a low gear like 1st. I let it coast at like 15mph and it was shaking and then i put it in nuetral and it stopped shaking but i was still moving. Is this my tranny starting to go, fluid needs to be changed or what?? It has a Jasper rebuild from two years ago.
Dominic Valenti is offline
post #2 of 7 (permalink) Old 08-28-2017, 12:57 AM
Project Shamu
Lt.Dan's Avatar
Re: 96 f350 Shaking Problems
This is a tough one to diagnose without being there.
I would start with checking the drivetrain, just get under the truck on a creeper and roll around for a little while. Grab the driveshaft and see if any of the u-joints have play, or if the carrier bearing is shot, see if any bolts are loose ANYWHERE. You'd be amazed at what you might find.
1996 Cali F350 CCFB, 7.3 PSD, 2wd SAS, w/ 380,000 miles.
New Motor at 352,000, DieselSite Legendary Trans at 356,000 and many more
Lt.Dan is offline
post #3 of 7 (permalink) Old 08-28-2017, 01:58 AM
FIRST thing to try is rotating the tires. See if it changes or goes away.
4x4 or 2WD truck?
madpogue is offline
post #4 of 7 (permalink) Old 09-04-2017, 02:11 AM
PSN
cscotted's Avatar
Did you do any suspension mods to rear axle? I'm wondering if u changed your pinion angle at all? Especially if u may have changed rear blocks from OEM. They don't always have the correct taper?
96 F250 CCSB 4x4 E4oD,4.30 gears, 37" tires, 2007 Suspension 160/30, S366 ,Banks IC, Adrenaline, e fuel, AFE, PRECISION TC
cscotted is offline
post #5 of 7 (permalink) Old 09-04-2017, 02:12 AM
PSN
cscotted's Avatar
Or if you have your joints out of phase
cscotted is offline
post #6 of 7 (permalink) Old 09-04-2017, 02:17 AM
I had a binding feel in my truck at low speed and went under to check u-joints, I found that the four bolts that hold the rear drive shaft to the output shaft on the transfer case were loose. I tightened them up and now it feels much better when starting/stopping and between shifts. Check those four bolts and u-joints for play.
ThomasWhite716 is offline
post #7 of 7 (permalink) Old 09-06-2017, 01:31 AM Thread Starter
ct_domv
Yes i found out my rear drive shaft ujoint has a lot of play in it, its been sitting and going to sit in my driveway untill i get a new ujoint for it
