Starting issue voltage on both sides of relay - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 08-25-2017, 02:31 AM Thread Starter
Exclamation Starting issue voltage on both sides of relay
Had a slow start issue with 1995 F250 7.3 turbo diesel. Batteries checked out fine, alternator failed, changed alternator. Still same issue, and starter failed test. Changed starter and starter relay, now battery acts dead. At starter relay and glow plug relay, I have 12.7 volts on one post and none on the 2nd post. If I have hood lifted, the factory hood light is lit. I can play the radio. When I try to crank engine, there is a loud click, hood light goes out and battery appears to be dead as a hammer. There is 12.7 volts on BOTH big posts of starter relay and glow plug relay now as well as 12.7 volts at starter. If I wait about 2 minutes, the hood light comes back on and there is only voltage on one of the posts again, instead of both. Also, when hood light goes out, entire fuse panel has almost no voltage (mV). Can it be a fusible link or wire going to PCM. Confused. Any help would be greatly appreciated.
allen1lt is offline
post #2 of 6 (permalink) Old 08-25-2017, 02:42 AM
Re: Starting issue voltage on both sides of relay
Check your ground terminals coming out of your batteries, had a similar issue and that was the problem for me.
Cortes977.3 is offline
post #3 of 6 (permalink) Old 08-25-2017, 02:51 AM Thread Starter
Thanks for the reply
allen1lt is offline
post #4 of 6 (permalink) Old 08-25-2017, 03:00 AM Thread Starter
Where would the back feed of voltage to the second terminal come from. When it makes the click noise, voltage appears on second terminal and makes everything electrical on the truck go out.
allen1lt is offline
post #5 of 6 (permalink) Old 08-25-2017, 04:09 AM
Bugman's Avatar
When the glow plug is energized you'll be sending voltage and a huge amount of amps to the glow plugs. This draw alone will kill a marginal battery or cause problems with a bad ground.
Bugman is online now
post #6 of 6 (permalink) Old 08-26-2017, 03:12 PM Thread Starter
Thanks so much to Bugman and Cortes977.3 for the info. Changed all battery terminals, took off grounds and wire brushed and sprayed with corrosion wash. Noticed very little corrosion. After cleaning up all grounds, truck acted exactly the same way. Noticed the grounds from both batteries went directly to engine ground and cable from engine ground to frame was 12G max, which surprised me. Went to AutoZone and connected 4G cable from engine ground directly to frame and it fixed it. Truck spins over super fast now. Wish I would've thought of this amazing site before buying a new starter, starter relay and alternator. At least I don't have to worry about them in the future.
allen1lt is offline
