HELP!!! Truck down need to repair asap! - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 3 (permalink) Old 08-23-2017, 12:18 PM Thread Starter
tractorman1215's Avatar
I have a 96 f250 7.3 I went to start it today and I got no wait to start light and CEL on. I checked fuse 22 it's good. I unplugged my chip no difference. I went to check for loose battery connections and the passenger side positive post was so hot it burned my finger. I recently replaced the pcm, it also has a strickley diesel Efuel kit. Truck will crank over no issues there. I need this truck back on the road my daily driver is down and I was using the 7.3 as a daily until I fixed my dakota. Please help thanks.
1996 F250 7.3 92k
4 inch lift 37's Goodyear mt military oz
Dana 60 king pin front axle conversion.
Riff Raff HPX Pipe.
Diamond eye 3inch down pipe, 5inch exhaust.
S&B Cold Air Intake
Hydra Chip
Driven Diesel Efuel kit
KC38R turbo
EBPV delete pedestal & output
Up and Coming
Intercooler
Rosewood Injectors
Rust and Rot
tractorman1215 is offline
post #2 of 3 (permalink) Old 08-23-2017, 02:17 PM
Re: HELP!!! Truck down need to repair asap!
Sounds like a major current draw. No direct experience, but I have seen reports where the fuel bowl heater will short and cause problems with that circuit (including the PCM), but will _not_ blow fuse #22. So I'd start with disconnecting that heater. Other possible draw is the GP relay; try disconnecting it.
madpogue is offline
post #3 of 3 (permalink) Old 08-23-2017, 10:22 PM Thread Starter
I tried putting my scan tool on it today and it wouldn't read it keeps saying error communicating with vehicle. I have a snap on brick scanner has worked in the past. Thoughts? I just replaced the pcm like a few months ago, however this isn't like that. When I condemned the pcm the first time no cel was on and I had to do a diagnostic trouble tree to figure out it was the pcm also there was no cel and the wait to start worked. This is different the cel is on immediately with koeo and no wait to start light.
1996 F250 7.3 92k
Riff Raff HPX Pipe.
S&B Cold Air Intake
Hydra Chip
KC38R turbo
Up and Coming
Intercooler
Rosewood Injectors
Rust and Rot
