Fuel lines - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 3 (permalink) Old 08-17-2017, 03:26 AM Thread Starter
Fuel lines
I am trying to replace the fuel line that runa from the front of the fuel bowl to the driver side head. I can't find a way to fit the wrench down there to loosen the line from the head. Does anyone know how to do this or if something has to be removed to access it? It's sandwiched between the engine and the Ac compressor.
Melamed555 is offline
post #2 of 3 (permalink) Old 08-23-2017, 03:53 PM
josh77's Avatar
Re: Fuel lines
seems like i had to pull the ac compressor when i did mine
97ccsb 4x4
395k miles
3"dp 4" exhaust
digital egt gage & trans temp
aeroforce intercptor single gauge
swamps ts chip
baby swamps
kc turbos billet wheel and 1.0 housing
dana 60 swap (all stock 350 stuff for now)
77 f150 4x4 rclb
getting a 4.6 4v with m5od soon (in process)
josh77 is offline
post #3 of 3 (permalink) Old 08-25-2017, 03:06 AM
Project Shamu
Lt.Dan's Avatar
Re: Fuel lines
Yes, you have to pull the compressor and the bracket that holds the vacuum pump/power steering pump. I've tried doing it while leaving it on, and its not possible.
1996 Cali F350 CCFB, 7.3 PSD, 2wd SAS, w/ 380,000 miles.
New Motor at 352,000, DieselSite Legendary Trans at 356,000 and many more
Lt.Dan is online now
