1997 f250hd xlt not starting after fuel bowl rebuild - PowerStrokeNation : Ford Powerstroke Diesel Forum
 2Likes
  • 1 Post By jrdonicht
  • 1 Post By Bugman
post #1 of 6 (permalink) Old 08-14-2017, 05:37 PM Thread Starter
Hey all,
I recently resealed the fuel bowl on my 97 7.3. I bought the o ring kit from dieselorings.com and followed their rebuild instructions. It went smoothly and the bowl is back in and I believe everything is hooked up correctly. The truck cranks smoothly and has a fully charged battery but won't catch and start. I filled the bowl with diesel to assist with priming and the level hasnt dropped at all.
Any help is much appreciated.
steadfast is offline
post #2 of 6 (permalink) Old 08-14-2017, 08:19 PM
Re: 1997 f250hd xlt not starting after fuel bowl rebuild
Originally Posted by steadfast View Post
Hey all,
Tripple check all the electrical connections especially the ipr.
410customs likes this.
jrdonicht is offline
post #3 of 6 (permalink) Old 08-14-2017, 08:38 PM
Bugman's Avatar
Are you getting the wait to start light? If not check fuse #22 under the hood.
Bugman is offline
post #4 of 6 (permalink) Old 08-15-2017, 01:43 AM Thread Starter
The wait to start light is on. The truck was running great, except for the leaky fuel bowl, before I did the rebuild. I tried squirting some starter fluid in to the air filter and it almost started. I had the bowl out for almost a week. Could it be that a lot of air got in the fuel system?
post #5 of 6 (permalink) Old 08-15-2017, 04:20 AM
Bugman's Avatar
Then I would check all the electrical connections again and like was mentioned above the IPR.
Bugman is offline
post #6 of 6 (permalink) Old 08-15-2017, 02:05 PM
410customs's Avatar
have you checked your wiring like these guys mentioned?
Don't use starting fluid on a diesel
If I am not mistaken the IPR two pin plug is similar to another two pin plug in the area so make sure you did not reverse the wiring pigtails.
Without the IPR plugged in it will not start
The IPR wiring is shared with the fuel bowl wiring, the water in fuel, the fuel bowl heater and the filter sensor are all tied into the same harness with the IPR wires, these all go through a single plug over by the glow plug relay....check your wiring
2001 Excursion 7.3, auto, 4x4, 3.73, 6" Suspension lift, 37" Dick Cepeks
2000 E350 7.3, auto 2wd, 3.73, planning a TTB 4x4 conversion
21.9 liter family
410customs is offline
