Bad shifting due to 0.04V dither? - PowerStrokeNation : Ford Powerstroke Diesel Forum
 1Likes
  • 1 Post By Mark Kovalsky
post #1 of 10 (permalink) Old 08-13-2017, 11:35 PM Thread Starter
I'm still having issues with my '95 7.3. (Basically, the PCM is randomly shifting the transmission out and back into 4th with the TC locked. When I say randomly, I mean very randomly: sometimes once in a 100 miles, other times chronically, with no relation to weather, temps, incline, driving conditions, etc.)
According to FORScan (using a high quality ODBLink SX USB cable) some sensors are showing a 0.04V dither (this is with the engine off, van immobile)
I've already replaced the PCM ($$$) to no avail.
I'm truly lost as to what to try next. Any suggestion would be welcome. I'm about ready to drive this thing into a canyon.
File Type: jpg Screen Shot 2017-08-13 at 12.38.50 PM.jpg (22.9 KB, 6 views)
ballo is offline
post #2 of 10 (permalink) Old 08-18-2017, 10:56 PM Thread Starter
Re: Bad shifting due to 0.04V dither?
Update: I captured a couple shifts and the voltage spikes with the MLPS co-incide with the temp gauge.
ballo is offline
post #3 of 10 (permalink) Old 08-19-2017, 01:14 AM
Pics are WAY too small to make out any detail; by "temp gauge", do you mean EOT? If so, I'd seriously consider replacing it.
madpogue is offline
post #4 of 10 (permalink) Old 08-19-2017, 07:20 PM Thread Starter
I uploaded full sized photos. This site resized them for whatever reason. It makes the photo attachment option a farce.
The image shows the TR_V and TFT_V roughly mirroring one another and spiking. When they go up by an appreciable amount, the PCM shifts the transmission out and back into 4th with the TC locked.
ballo is offline
post #5 of 10 (permalink) Old 08-19-2017, 07:25 PM Thread Starter
So it seems the site doesn't like png (or even .jpg, but instead needs .jpeg to avoid resizing). Let's try this again using old formats.
ballo is offline
post #6 of 10 (permalink) Old 08-19-2017, 10:08 PM
If you resize them to something web-reasonable (say, 1024x768) before uploading, the site doesn't resize them to something even smaller.
So "temp" refers to tranny temp? Hmm, just a WAG, but perhaps the tranny temp sensor is flaking. Or a connection issue with the harness down to the tranny. Sorry, I'm not familiar with the automatics. I forget which sites he's on, but look here and on the other Ford-related truck sites for a guy name Mark Kovalsky. He's Mr. Ford Automatic Transmisson; the guy has Type F running through his veins. Those correspondences between voltage, tranny temp and the shifting might mean something to him.
madpogue is offline
post #7 of 10 (permalink) Old 08-20-2017, 12:27 AM Thread Starter
Not true. In fact my screen shots were smaller than that. I'll attach another screen shot which shows the very odd rules of this site. All I did was convert from the lossless png to a lossy (harder to read test) jpg then rename it to jpeg.
Don't know him
ballo is offline
post #8 of 10 (permalink) Old 08-20-2017, 01:29 AM
Former Ford Trans Engr.
Mark Kovalsky's Avatar
The entire problem could be the TR voltage going up. The PCM sees this as you moving the shift lever from D to 2, so it downshifts. If it isn't a spike from an alternator problem it's a failing TR sensor. This won't set any codes until the sensor gets really, really bad. The only fix if this is the problem is a new TR sensor.
Not true. It used to be MERCON V, now there is MERCON LV running around in there.
JCart likes this.
Mark
Mark Kovalsky is offline
post #9 of 10 (permalink) Old 08-20-2017, 02:13 AM Thread Starter
MLPS sensor was the first sensor replaced (NAPA part) and no behavior changed.
ballo is offline
post #10 of 10 (permalink) Old 03-05-2018, 10:08 PM Thread Starter
So I've been going through various diagnostic schedules in the service manual and came across a possible problem. The voltage to the tranny temp sensor is a little out of spec. It measures at 4.61 volts instead of 4.75 - 5.25 volts (I'll try to attach a photo). I tested it with two high quality meters, but using the same leads. Could this be my problem? The PCM has already been replaced in an attempt to fix my tranny issues.
ballo is offline
