97 f250 hd 7.3. 415k truck starts & few seconds later cel comes on& runs ruogh - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 13 (permalink) Old 08-11-2017, 02:33 PM Thread Starter
Hey yall..otherday my truck was running while i loaded brush on trailer..it started sounding funny & cel was on & sounded like running out of fuel..& then would level out& cel would cut off..but then come back on..i have checked all fuses..changed cps..& new uvc harness& gasket on passenger side..it is still acting up..i would have to have it towed to next town over to get codes read..so any help will be appreciated ..thank yall
Jordan brooks is offline
post #2 of 13 (permalink) Old 08-11-2017, 03:14 PM
Former Ford Trans Engr.
Mark Kovalsky's Avatar
Re: 97 f250 hd 7.3. 415k truck starts & few seconds later cel comes on& runs ruogh
Without the codes you'll have a very hard time fixing this.
Mark
Mark Kovalsky is offline
post #3 of 13 (permalink) Old 08-11-2017, 03:34 PM Thread Starter
Yes sir nobody in my town can do the deisel codes..bout an hour tow
post #4 of 13 (permalink) Old 08-11-2017, 03:55 PM
alleged moderator
tjctransport's Avatar
if you have a smart phone, laptop, or tablet, you can download torque pro or forscan for under $5 each.
i do not like forscan, i can not get it to work. but others swear by it.
with an ELM adapter or a computer to OBD port connector you can do all kinds of things.
pretty much a must have tool these days as it will save you money instead of paying to have codes read every time.
tom
tjctransport is offline
post #5 of 13 (permalink) Old 08-11-2017, 04:21 PM Thread Starter
Ok thank you ill have to try that..i did find a freind that runs a big rig shop& has codes reader supposed to swing by shortly..
& want to say thank you to yall fellas on here ive been using this site to fix truck for years..1st time i havent been able so figured i would sign up..so thank yall
post #6 of 13 (permalink) Old 08-11-2017, 05:50 PM
alleged moderator
no problem!!.
that is what we are here for, to help....................and sometimes give a hard time.
tom
post #7 of 13 (permalink) Old 08-11-2017, 07:05 PM Thread Starter
My codes wouldnt read with freinds scanner..but i told him bout tps problem few weeks ago. I cleaned connectors & was working fine.till 2 days ago.so i was told to replace tps..i did & now i get no throttle response at all .am i missing something in the instalation?
post #8 of 13 (permalink) Old 08-11-2017, 10:05 PM
alleged moderator
not all scanners will read diesel codes.
you need one made to read diesels.
tom
post #9 of 13 (permalink) Old 08-11-2017, 11:51 PM
Bugman's Avatar
you need one made to read Ford diesels.
Fixed it for you.
Bugman is online now
post #10 of 13 (permalink) Old 08-12-2017, 12:14 AM Thread Starter
Yes sirs i asked freind 1st if able to read my truck he owns a 18 wheeler repair shop..but no go..
I tried a tps at hisadvice put 2 different tps on ..dead pedal..put origanal back on trucks been running 30 mins no problem no cel..fingers crossed my truck healed itself
