97 powerstroke miss new to forum - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 5 (permalink) Old 08-11-2017, 03:04 AM Thread Starter
Powerstroke4003's Avatar
Im new to the forum. I have a 1997 F-superduty 7.3 manual. Ive had the truck since January and have fixed every problem I've had in this short time frame my self. This problem has gotten the best of me and I can't figure it out. In early May I took the truck out to dinner and on my way back I had the 140+ tune on and did a few pulls. Usually not like me, but I love turbo anything. I was watching my EGT gauge and thought the truck was fine.
Next morning I went out to start the truck for work. The truck started, ran for a couple seconds then died like it was running out of fuel. The truck started right back up and ran rough for a few more seconds then died again. My fuel gauge was at a 1/4 on the front tank. So I thought my pickup in the tank fell off. I switched to the back tank at 1/2tank and cranked. It took all weekend, charging batteries, cranking, batteries, cranking and it started.
I took the truck out for a drive to get any air that was in the system out, Filled the tanks and went for a 30-40 mile drive. While out driving around, my truck stumbled at 1500rpm consisantly (like it dies for a second then starts again). The problem occurs from 1500rpm while under load to 2000rpm while in neutral.
Also the truck also has a intermittent popping noise out the exhaust when my high idle is on. Now the truck does it very faintly at idle too. I made a youtube video of it running with the high idle on. You can hear the popping noise in the vid.
I initially thought it was a bad CPS because of all the 7.3 owners on here who have problems with their cps. I put in a new BWD CPS.
I pulled the filter to see what the bottom of the fuel bowl looked like and it was filled with 1/4inch of gunk on the bottom and had a black film on the inside of the bowl. So my solution was to do a tightwad mod. A new filter water separator and housing. Modified
FPR to return line. I got everything installed and noticed my fuel pump was leaking a lot out the weep hole. I put in a new mechanical fuel pump on and the truck seems a lot more responsive. But the problem still persists.
I then pulled the valve covers to start unplugging injectors to see if one was dead. When I unplugged each injector the only one that sounded like it had no change was the back drivers side. I installed a used injector in its place. No change
While taking the valve covers off I noticed one of the drivers side gasket plugs was melted. I changed that UVCH, glow plugs, and relay.
Then after buying parts, wasting money, and the truck still not fixed I bought a Snap-On MTG2500 scanner so I can run a CCT, buzz test, and monitor ICP IPR injector pulse while it misses. Everything checks out within spec.
I also have a P0344, P0475 in the memory codes. I know the Exhaust pressure control valve code is in there because I put a deleted pedestal in. The intermittent CPS code makes me want to test the wires going from the cps to the pcm.
All help or thoughts are greatly appreciated.
Powerstroke4003 is offline
post #2 of 5 (permalink) Old 08-13-2017, 06:44 PM Thread Starter
Re: 97 powerstroke miss new to forum
top
"If your not first your last" ~Ricky Bobby
post #3 of 5 (permalink) Old 08-13-2017, 07:34 PM
79jasper's Avatar
There's a reason to people saying motorcraft parts only.
Pull the tank senders to see if the pickups broke off. You could have pieces in the lines/selector valve.
Sent from my SAMSUNG-SM-G890A using Tapatalk
79jasper is offline
post #4 of 5 (permalink) Old 08-13-2017, 10:24 PM Thread Starter
I bypassed the tank and selector with 3/8 fuel line from a clean diesel can to the pump and ran it for 10min. Truck still skips around 2000rpm with intermittent popping from exhaust. I ordered new o-rings for my injectors. Should be here Wednesday. I sent the new back because the truck wouldn't start with it and was getting a PCM-IDM communication code. Truck starts and runs with the old one.
post #5 of 5 (permalink) Old 08-13-2017, 10:28 PM Thread Starter
I sent the new IDM back because the truck wouldn't start with it and was getting a PCM-IDM communication code. Truck starts and runs with the old one.
