Replacing U Joints on rear shaft - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 3 (permalink) Old 08-10-2017, 10:47 PM Thread Starter
I have a 97 F250 CCSB 4wd and I want to replace the three u joints beginning at the back of the transfer case. Do I need to unbolt the carrier bearing in order to pull both pieces of the rear drive shaft down?
Melamed555 is offline
post #2 of 3 (permalink) Old 08-10-2017, 11:14 PM
Re: Replacing U Joints on rear shaft
yes, it is pressed on...think about changing that "center support bearing" also
1996 F350 Crewcab lb 2wd auto, tommylift, now over 451k, 355k 3/31/15
1991 F250 Xtracab lb 2wd auto, sold again! Driveline and chassis is under a '65 F350 cab
1965 F100 styleside, power brakes, front discs, 390 all the goodies
2015 F250 CCSB 2wd gasser auto
2008 Mustang WIP, warriors in pink, wife's
2009 Focus, son's
aussamdad is offline
post #3 of 3 (permalink) Old 08-11-2017, 12:19 AM Thread Starter
Do I need a special tool to replace the support bearing? I read online that some people use a double/triple jaw puller to pull that bearing out.
