95 f350 cali emissions 84k mile truck - PowerStrokeNation : Ford Powerstroke Diesel Forum
 1Likes
  • 1 Post By cpdad93
post #1 of 8 (permalink) Old 08-09-2017, 08:52 PM Thread Starter
sprayed347's Avatar
just picked up a 95 f350 4 door socal truck no rust only 84k miles but it has build codes of of emooc andemc for cali emissions compliant. I am in Missouri so that is not needed it is my first diesel truck. what does the cali emissions consist of on these trucks?can it be tuned out with software or is there some mechanical devices that need to go also.This truck is stock as a rock.
sprayed347 is offline
post #2 of 8 (permalink) Old 08-09-2017, 11:39 PM
Re: 95 f350 cali emissions 84k mile truck
There were no different California emmissions controls on a '95.
madpogue is offline
post #3 of 8 (permalink) Old 08-10-2017, 01:33 PM Thread Starter
sprayed347's Avatar
good deal
post #4 of 8 (permalink) Old 08-11-2017, 04:01 AM
Patrick Feeley's Avatar
California-specific differences did not start until late-1996 with the introduction of splitshot injectors and some corresponding programming and fuel system changes. Even more changes in 1997 with PCMs with different pin-outs, glowplug monitoring circuits, etc. Cheers!
SOLD: 94 F350 CC DRW PSD, 5 Speed, 4.10 LS, SBC Con-O, Baldwin Filter, Tymar HPX Hose, 3” DP, Bilsteins, $12 AIC, Coolant Filter, Explorer O/H Console, Trans Temp, Boost, and Pyro, Pedestal Mod, Gutted EBPV
Patrick Feeley is offline
post #5 of 8 (permalink) Old 08-11-2017, 05:17 AM
Project Shamu
Lt.Dan's Avatar
The california emissions trucks were actually capable of making more power than the 49-state trucks, due to larger injectors. The 96 was the best year due to very little differences in PCM's or wiring compared to the 49-state trucks.
A 95 "california" truck just means it was sold in Cali. I think.
Like Patrick said, the "California emissions" models didnt start till late-96.
1996 Cali F350 CCFB, 7.3 PSD, 2wd SAS, w/ 380,000 miles.
New Motor at 352,000, DieselSite Legendary Trans at 356,000 and many more
Lt.Dan is offline
post #6 of 8 (permalink) Old 08-11-2017, 02:45 PM Thread Starter
sprayed347's Avatar
good deal thanks guys. this truck is very clean except for the carpet needs replaced,this poor truck had a large lance 2200 lb camper on it for 17 years...
post #7 of 8 (permalink) Old 08-14-2017, 04:45 AM
cpdad93's Avatar
make sure to check the bed for illegals
sprayed347 likes this.
cpdad93 is offline
post #8 of 8 (permalink) Old 08-21-2017, 08:49 PM Thread Starter
sprayed347's Avatar
hahahahaha. so iam thinking of 3 inch down pipe 4 inch exhaust,235 85 16 tires, and a 6 position chip.
