95 died - PowerStrokeNation : Ford Powerstroke Diesel Forum
 6Likes
post #1 of 24 (permalink) Old 08-08-2017, 06:18 PM Thread Starter
Deiseldaddio's Avatar
95 died
drove 3 hr up in mountains I70 Eisenhower tunnel got to campsite shut off and hasn't started since. little or no fuel pressure, changed pump same thing little or no fuel press. batteries good cranks fast shows no signs of starting just cranks. WTS light comes on, all fuses look good. any help would be appreciated. Changing pump at campsite no picnic, took 4 days.
Thanks Kirk
tow truck guy pulled plastic handle off oil dipstick, cant get it out, any thoughts?
95 F-350 Crewcab Long Bed Auto Trans
Terminator HPOP, Inter cooler, Full Force Stage 1's, Banks Down Pipe, Tymar Filter, Tymar 4" Exhaust, F.P.R.Shim,Pac-Brake,Autometer Z Series Pyro, Trans Temp, and Boost,DIY Coolant Filter, A Pillar Mnt, DIY Bypass Oil Filter, Tru-Cool Max Tranny Cooler, TS 6 Position Chip, Valve Body By Cale at BTS
Deiseldaddio is offline
post #2 of 24 (permalink) Old 08-08-2017, 06:27 PM
Moderator
Sbluke55's Avatar
Re: 95 died
What's you fuel level at? Have you tried switching tanks.
What part of Colorado are you in? I'm over in grand junction
01 f-250, Standard
Sbluke55 is online now
post #3 of 24 (permalink) Old 08-08-2017, 06:33 PM
Moderator
Sbluke55's Avatar
Re: 95 died
Also how long have you cranked on it after you changed the fuel pump. It can take a while to prime up.
01 f-250, Standard
post #4 of 24 (permalink) Old 08-08-2017, 06:52 PM Thread Starter
Re: 95 died
Aurora
front less than 1/4, back full
switched tanks several times
Thanks Kirk
post #5 of 24 (permalink) Old 08-08-2017, 07:10 PM Thread Starter
Re: 95 died
drove up to camp site backed in unhooked trailer shut off truck 15-20 mins later no prob starting drove around camp site to water pump. got som water for trailer. got in truck turned key no start just that quick
post #6 of 24 (permalink) Old 08-08-2017, 07:46 PM
Moderator
Sbluke55's Avatar
Re: 95 died
I would toss 5-10 gallons in the front and crank it. Make sure the fuel bowl is full. Crank for a few. Check the bowl. Crank for a few. Check the bowl. Top off as needed.
01 f-250, Standard
post #7 of 24 (permalink) Old 08-08-2017, 08:35 PM
Native Texan
masakimm's Avatar
Garage
Re: 95 died
When mine ran out on me in the gas station parking lot 15 ft from the pumps. It took alot of cranking to reprime the system. Never thought of adding fuel to the bowl. If you can get it to fire it will prime quickly. Your foot is probably gone off the pick up in the tank. If the fuel station hadn't been on a hill I probably would have made it. It does not take these trucks long to empty the fuel filter housing.
Sent from my Super awesome outdated Samsung that doesn't burst into flames using Tapatalk
Sbluke55 likes this.
Upgrades:
masakimm is offline
post #8 of 24 (permalink) Old 08-08-2017, 08:59 PM
Moderator
Sbluke55's Avatar
Re: 95 died
With the fuel pump being a two stage pump. Fuel goes into the pump, then to the filter at a low psi through the filter and back to the pump and then to the injectors. If you can get it to fire off the fuel in the bowl it should prime the rest of the system.
I know you said you tried to change tanks but it could be stuck and the fuel pickup foot could of fell off. It's easy to check with just some more fuel.
01 f-250, Standard
post #9 of 24 (permalink) Old 08-09-2017, 04:30 PM Thread Starter
Re: 95 died
well after charging batts all day and cranking the stuffing out of it, I have more press at the schrader valve still no fire. after hrs of thought, I switched the tanks when I started it up to get the water, 1/4 mile drive then shut it off. do the selector valves or transfer valve go bad?
post #10 of 24 (permalink) Old 08-09-2017, 05:29 PM Thread Starter
Re: 95 died
went out and put my hand on transfer valve had granddaughter operate switch, valve motor came on in both directions so I would say not stuck.
can I blow air back through the feed line into the tanks?
