Reseal Intake Plenum - PowerStrokeNation : Ford Powerstroke Diesel Forum
 4Likes
post #1 of 21 (permalink) Old 08-03-2017, 02:44 AM Thread Starter
Diabolic1's Avatar
I have located a small leak on the passenger side plenum. I was going to order some new stock replacement plenums along with the anti crush sleeves. I have e-fuel so my fuel bowl and pump have been removed. It doesn't appear that the turbo will need removed in order to remove the passenger side. I seem to recall reading that my 97 has the 10 bolt plenums. I also recall hearing about one bolt that is difficult to remove.
Any tips or tricks here? Turbo on or off? What about that one problem bolt? Thanks!
longjonsilver likes this.
1997 CCSB, 7.3/E4OD
KC TP38R, CNC Fab Bellowed Up-Pipes, Full Force Stg 1 injectors, 3" DP, 4" exhaust, CNC Fab HPOP, Mark F E-Fuel, 7.3 Intercooler, 1.0 Exhaust Housing, TS Chip, remote coolant filter, and VB.
Diabolic1 is offline
post #2 of 21 (permalink) Old 08-03-2017, 03:01 AM
'Cody''s Avatar
Re: Reseal Intake Plenum
If you just do the passenger side you should not need to remove the turbo. I also had to do this a few years ago. Its pretty straight forward, just takes time.
Make sure to use the mortorcraft gray rtv. Its good stuff.
How did you discover the leak? Are you sure the drivers side isn't also leaking?
Old Blue, 97' F350, CCLB, 7.3, Auto
Air: SD IC, 3" Plenums
Fuel: E- Fuel, 160/30 Injectors
Turbo: Irate T4, S366
Oil: T500, Melling LPOP
PCM: TW TS, IDM Mod
'Cody' is offline
post #3 of 21 (permalink) Old 08-03-2017, 04:10 AM Thread Starter
Diabolic1's Avatar
I pressurized the Intake tract with compressed air. I could hear air hissing out, sprayed soapy water and it started hissing and making bubbles.
1997 CCSB, 7.3/E4OD
post #4 of 21 (permalink) Old 08-03-2017, 04:11 AM Thread Starter
Diabolic1's Avatar
Where can I buy new stock plenums?
1997 CCSB, 7.3/E4OD
post #5 of 21 (permalink) Old 08-03-2017, 04:20 AM
Project Shamu
Lt.Dan's Avatar
I can just leave this here... :)
Riffraff Diesel Billet Intake Manifold Plenums for Ford 7.3L 94-03
1996 Cali F350 CCFB, 7.3 PSD, 2wd SAS, w/ 380,000 miles.
New Motor at 352,000, DieselSite Legendary Trans at 356,000 and many more
Lt.Dan is offline
post #6 of 21 (permalink) Old 08-03-2017, 04:26 AM Thread Starter
Diabolic1's Avatar
Says it won't fit with stock turbo. I have a stock turbo and E99 spider. My stock plenums lasted 20 years. I'd like to go back with stock if they are available.
1997 CCSB, 7.3/E4OD
post #7 of 21 (permalink) Old 08-03-2017, 04:31 AM
'Cody''s Avatar
Intake Plenum Manifold Cover - Early 99 - Riffraff Diesel Performance
You might call them to see when they will be back in stock.
Why do you need to buy a new one? Why can't you reuse the old one?
PCM: TW TS, IDM Mod
'Cody' is offline
post #8 of 21 (permalink) Old 08-03-2017, 04:43 AM Thread Starter
Diabolic1's Avatar
Just seems like parts like that get tweaked when removing them, then they leak. When I remove old parts, I like to go with new stuff it oem is available.
1997 CCSB, 7.3/E4OD
post #9 of 21 (permalink) Old 08-03-2017, 05:13 AM
Project Shamu
Lt.Dan's Avatar
F6TZ9E434BA OEM GENUINE FORD FACTORY COVER NEW | eBay
I didn't realize that Riffraff must not make them for 2" plenums. My bad lol
Lt.Dan is offline
post #10 of 21 (permalink) Old 08-03-2017, 02:00 PM Thread Starter
Diabolic1's Avatar
I bought that eBay plenum. Can I buy that gray silicone at Ford, or can I use "The Right Stuff?"
1997 CCSB, 7.3/E4OD
