Engine Shutters like it's about to Stall - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 9 (permalink) Old 08-02-2017, 12:51 AM Thread Starter
I have a 1997 CCSB F250 4WD ZF5. When I drive the truck and come to a stop on any type of incline or hill the truck shutters like it is about to stall out. This happens when I am in neutral with my foot off the clutch. While I am driving the truck everything is fine for the most part. One other problem is that sometimes as I am shifting gears the truck likes to slam. This will happen when I am driving the truck normally and not dropping the clutch or anything like that. The only way I can stop it from happening is if I am extremely light on the throttle after letting the clutch out in the next gear.
A while before this problem happened I buzz tested my injectors and they all came up fine(I had a weird idle which turned out to be a bad CPS). When I ran the cylinder contribution test(shuts off each injector while the truck is running to test) it told me that all eight injectors failed which seemed a little weird to me. I had a slightly low fuel pressure at the regulator(about 55psi) and the fuel pump was leaking anyway so I replaced the fuel pump.
I am not sure if this could be related but I replaced the clutch, flywheel, pressure plate and throwout bearing the day before this problem started happening. is it possible that I could have damaged a wire under the truck near the trans that could cause this? I installed a Southbend clutch which is rated for 475HP and 1000ftlb. The truck probably only makes about 270 at the moment but I am getting new injectors this week and a bigger turbo in a few months so I wanted to have a clutch that would support the extra power.
Any ideas on a possible problem or solution would be greatly appreciated.
Melamed555 is offline
post #2 of 9 (permalink) Old 08-02-2017, 02:16 AM
79jasper's Avatar
Re: Engine Shutters like it's about to Stall
Tunes?
Sent from my SAMSUNG-SM-G890A using Tapatalk
79jasper is online now
post #3 of 9 (permalink) Old 08-02-2017, 04:48 AM
Trust me, I got this...
Cummins Junkie's Avatar
Garage
This doesn't happen on more level ground? Only on inclines?
Shoulda bought a Cummins.
1997 F250 7.3L XLT, 4x4, 5spd, 315K, TS chip, BD Turbo-Thruster II, Donaldson 6637 filter, 4" straight piped dual exit SOLD
1995 F350 CCLB 6.0L WIP
Pain is inevitable. Suffering is optional.
Cummins Junkie is offline
post #4 of 9 (permalink) Old 08-02-2017, 04:33 PM Thread Starter
I have an intake, exhaust and a php hydra chip, and yes this only happens on inclines.
post #5 of 9 (permalink) Old 08-02-2017, 04:49 PM
Moderator
Sbluke55's Avatar
I'll bet you $20 on your ipr tin nut is gone.
01 f-250, Standard
Sbluke55 is online now
post #6 of 9 (permalink) Old 08-03-2017, 01:57 AM Thread Starter
Can I just buy a nut that is the same size? Does anyone know the size of the bolt or where I could buy a replacement?
post #7 of 9 (permalink) Old 08-03-2017, 03:50 AM
Moderator
Sbluke55's Avatar
Its most likely just sitting in the valley
01 f-250, Standard
post #8 of 9 (permalink) Old 08-03-2017, 03:50 AM
Moderator
Sbluke55's Avatar
So was it gone or you just getting things lined out.
01 f-250, Standard
post #9 of 9 (permalink) Old 08-11-2017, 06:20 AM Thread Starter
You were right, it was gone. I just bought a new apr valve and replaced it. I am keeping the old one as a spare because the nut being gone was what made it have these problems. Thank you so much for the help!
