Engine that has sat for ten years - PowerStrokeNation : Ford Powerstroke Diesel Forum
 1Likes
post #1 of 11 (permalink) Old 08-01-2017, 02:25 AM Thread Starter
So looking for a used 7.3 powerstroke and there are a few out there that have sat for some time. What's the downside concern with one that has sat for say 10 years? Low mileage sat under 150,000 Kms. If you bought one would you open it up or install and try to fire up? Any suggestions would be great.
j
Tan white tan 97 ECLB, D60 PMF, RSK SD springs front, airs bags rear, 4:10s 37 Toyo R/Ts intake, FFD 205/30s, DP 4 exhaust DIY E-fuel, ZF-5 now
lights: VisionX & HID projectors in headlights.
JCart is offline
post #2 of 11 (permalink) Old 08-01-2017, 02:36 AM
Project Shamu
Lt.Dan's Avatar
Re: Engine that has sat for ten years
Check compression, then pull the injectors out and see if you can see any rust in the cylinders, maybe one of those scope cameras would help.
Drain whats in the pan (if there is anything) and see if you find anything other than oil. (specifically water, fuel, coolant, sludge, etc).
If you are at all worried about it, just pull the heads off, best case scenario everything is fine, you buy some headgaskets and bolts ($3-400), and you get the heads and block decked to ensure flatness ($2-300), and you put it back together with some piece of mind.
The oil pan can come off with just a few bolts as well, make sure everything is atleast still in one piece...
1996 Cali F350 CCFB, 7.3 PSD, 2wd SAS, w/ 380,000 miles.
New Motor at 352,000, DieselSite Legendary Trans at 356,000 and many more
Lt.Dan is offline
post #3 of 11 (permalink) Old 08-01-2017, 03:35 AM
'Cody''s Avatar
The engine currently in my truck sat for 6 years I was told. I had no idea what shape the internals where in. I pulled the oil pan and checked the cylinders best I could by running each piston to tdc. It rolled over smooth and all the cylinders looked good so I cleaned it up, painted it, installed my goodies, and dropped it in. I currently have 0 fluids leaking and it runs like a champ. Probably the best $450 I ever spent.
If they sit too long the gaskets and o rings can go bad. Also rust is a concern depending how and where it was stored. If it looks good I say run it and see what happens. What's the worst that can happen?
Old Blue, 97' F350, CCLB, 7.3, Auto
Air: SD IC, 3" Plenums
Fuel: E- Fuel, 160/30 Injectors
Turbo: Irate T4, S366
Oil: T500, Melling LPOP
PCM: TW TS, IDM Mod
'Cody' is offline
post #4 of 11 (permalink) Old 08-01-2017, 05:33 AM
Trust me, I got this...
Cummins Junkie's Avatar
Garage
Wouldn't pull it apart unless I knew it was necessary. Change fuel and oil filters, fill the fuel bowl with atf, put fresh oil in it, probably test the glow plug relay and glow plugs to see if they still work. After that i'd crank it over and see what happens.
That is, assuming I would even purchase an engine thats sat for a decade.
Shoulda bought a Cummins.
1997 F250 7.3L XLT, 4x4, 5spd, 315K, TS chip, BD Turbo-Thruster II, Donaldson 6637 filter, 4" straight piped dual exit SOLD
1995 F350 CCLB 6.0L WIP
Pain is inevitable. Suffering is optional.
Cummins Junkie is offline
post #5 of 11 (permalink) Old 08-01-2017, 05:38 AM
Master BS'er
jamiesaun's Avatar
Agreed. I'm betting it will be fine. Change the oil and fuel filters, drain the fuel and let her rip. You'll have to run it to see what's wrong with it anyway.
Brother James
Ps...Im pretty frickin awesome!
jamiesaun is offline
post #6 of 11 (permalink) Old 08-01-2017, 05:41 AM
Michael James McCreary's Avatar
I would crank it to see if it's free after checking all the fluids. Checking the dash lights for glow relay problems. Then remove the fuel line from the lift pump. Remove the filter and flush the tank and lines. Use biocide to kill all the microbes. Put in fresh fuel, purge system of air and it should run like a champ. Mine did. It sat for 6 or 7 years and came to life with just a few hundred dollars in oil, filters, fuel cleaners, glow plugs and relay.
Michael James McCreary is offline
post #7 of 11 (permalink) Old 08-01-2017, 07:05 PM Thread Starter
Thanks Guys,
Bit of a crap shoot I understand, just chewing on options. In addition I own a couple high km engines (read 500,000 Kms) and to strip and rebuild is significant here. So thinking I'll continue to try and find a used lower km engine and if it's bad least I'll have (in theory) lower Kms on the rolling assemblies? My 500k engines have been sitting for 3-7 years and are low compression and think would need lots of attention.
Thanks again.
j
JCart is offline
post #8 of 11 (permalink) Old 08-01-2017, 07:24 PM
Moderator
Sbluke55's Avatar
I didn't read any of the posts. But what I would do is pull all the glow plugs and dump so oil in the cylinders and bar it over a few times. Then crank it to clear the cylinders. Then compression check.
01 f-250, Standard
Sbluke55 is offline
post #9 of 11 (permalink) Old 08-02-2017, 03:51 AM
Project Shamu
Lt.Dan's Avatar
That is actually a good idea ^, make sure the rings are lubricated that way.
Lt.Dan is offline
post #10 of 11 (permalink) Old 08-02-2017, 11:08 AM
Master BS'er
jamiesaun's Avatar
Yeah, that is a pretty good idea, real good actually. Since the plugs are out, it wouldn't be a bad time to do that I reckon. It would also be a good idea to dump some oil under the valve covers. If ya wanted to give the engine it's best shot, those are the things one should so. Along with turning it over by hand maybe a couple dozen times or so, which would prime it. A dry start is never a good thing. I personally wouldn't do any of that, but I never said I was smart, plus I get lazy at times.
Have any of you guys ever seen break in oil before? It's crazy, with all the steel and chrome and whatnot, it looks like Jupiter when you stir it. It's quite pretty actually.
410customs likes this.
Brother James
