No start when hot. - PowerStrokeNation : Ford Powerstroke Diesel Forum
 3Likes
post #1 of 16 (permalink) Old 07-25-2017, 06:34 AM Thread Starter
Freak of Nature
Coopons's Avatar
Garage
No start when hot.
Won't start when hot. Changed injector o'rings on all 8 cylinders. About 4 sets were toast. Also changed vcg and harness. Fires right up when cold but won't restart when hot. Let it cool down and she fires back up. Any ideas?
Coopons is offline
post #2 of 16 (permalink) Old 07-25-2017, 01:58 PM
410customs's Avatar
Re: No start when hot.
CPS and IPR are suspect as well as weak or leaky high pressure oil system
Any check engine light?
Coopons likes this.
2001 Excursion 7.3, auto, 4x4, 3.73, 6" Suspension lift, 37" Dick Cepeks
2000 E350 7.3, auto 2wd, 3.73, planning a TTB 4x4 conversion
21.9 liter family
410customs is offline
post #3 of 16 (permalink) Old 07-25-2017, 03:07 PM
79jasper's Avatar
Cps usually doesn't cause hot start issues, but it is still a electrical component. Lol
My money would be ipr. Notorious for no hot start. Try pouring cool water on the solenoid when it won't start.
Sent from my SAMSUNG-SM-G890A using Tapatalk
Coopons likes this.
79jasper is offline
post #4 of 16 (permalink) Old 07-25-2017, 03:57 PM Thread Starter
Freak of Nature
Coopons's Avatar
Garage
When the problem first happened, i had just driven about 250km, i stopped to top up my fuel. it was a really hot day, no start after filling up. my first thought was cps. Like all good powerstroke owners i had a brand new one in the glove box. replaced it and she fired right back up. I figured the problem was solved. i arrived at my destination another 300km. truck was parked for about a week. Left there and drove about 200km stopped for coffee, no start. let it kool down for 20mins it restarted but it was a struggle to start. lots of cranking. when its running it runs awesome. No CEL.
1996 F350 ccsb
Dana 60 swap
3" DP 4" straight pipe
6637 air filter
Adrenaline HPOP
Explorer overhead console
SD 120v IDM
Super duty Lariat seats
315/75R16
Coopons is offline
post #5 of 16 (permalink) Old 07-25-2017, 04:00 PM Thread Starter
Freak of Nature
Coopons's Avatar
Garage
Is there any way to check the IPR? I'm not at home so my tools are very limited. Jasper I'll take it for a drive and see if the cool water will work. Very fustrating as this truck has never given me any trouble.
1996 F350 ccsb
Dana 60 swap
6637 air filter
Adrenaline HPOP
SD 120v IDM
315/75R16
Coopons is offline
post #6 of 16 (permalink) Old 07-25-2017, 04:20 PM Thread Starter
Freak of Nature
Coopons's Avatar
Garage
another quick question. What should my RPM's be when cranking? And i noticed it doesn't build oil pressure on the gauge when its hot.
1996 F350 ccsb
Dana 60 swap
6637 air filter
Adrenaline HPOP
SD 120v IDM
315/75R16
Coopons is offline
post #7 of 16 (permalink) Old 07-25-2017, 04:53 PM
79jasper's Avatar
You can check the resistance of the ipr solenoid. Cold vs hot.
I can't remember the exact ohm value for "good."
The oil pressure gauge on these trucks is a joke. It's actually a oil pressure switch. 7psi and it makes the gauge move.
Coopons likes this.
79jasper is offline
post #8 of 16 (permalink) Old 07-25-2017, 05:00 PM Thread Starter
Freak of Nature
Coopons's Avatar
Garage
Jasper, just got back from a drive and tried the cool water trick. No dice. I just talked to a friend of mine, he's a heavy duty diesel mechanic, he's going to bring home his computer from work. Hopefully that can narrow it down. Thanks for all the advice. Its just crazy that the truck runs so well.
1996 F350 ccsb
Dana 60 swap
6637 air filter
Adrenaline HPOP
SD 120v IDM
315/75R16
Coopons is offline
post #9 of 16 (permalink) Old 07-25-2017, 05:25 PM
79jasper's Avatar
That should help a lot.
79jasper is offline
post #10 of 16 (permalink) Old 07-26-2017, 04:31 PM
True, but it should still register while cranking, cold or hot. If indeed it's not responding at all when hot, that seems to point to the problem. Oil is low, or old/thin, or lube oil pump is not providing sufficient pressure when hot.
madpogue is offline
