Dana 60 swap driveshaft issue - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 8 (permalink) Old 07-23-2017, 07:06 PM Thread Starter
Hey guys I recently swapped in a Dana 60 from a 96 f350 into my 97 f250, everything went smoothly until I tried to hook up my driveshaft. I bought the f350 driveshaft with the axle because I heard it was a better driveshaft than the f250 but when I bolted it up to the axle, it was way too short and couldn't reach the transfer case, what could be the reason for this? Thanks
GAobs is offline
post #2 of 8 (permalink) Old 07-23-2017, 07:29 PM
Native Texan
masakimm's Avatar
Garage
Re: Dana 60 swap driveshaft issue
It has a collapsible section are u sure its not just collapsed.
Sent from my Super awesome outdated Samsung that doesn't burst into flames using Tapatalk
Upgrades:
masakimm is offline
post #3 of 8 (permalink) Old 07-23-2017, 08:32 PM
Native Texan
masakimm's Avatar
Garage
The other option is the drive shaft is for the wrong transmission. The manual is shorter then an automatic.
Upgrades:
masakimm is offline
post #4 of 8 (permalink) Old 07-23-2017, 08:34 PM
Project Shamu
Lt.Dan's Avatar
That, or depending on what lift you are running, it might just be plain ol' too short now.
1996 Cali F350 CCFB, 7.3 PSD, 2wd SAS, w/ 380,000 miles.
New Motor at 352,000, DieselSite Legendary Trans at 356,000 and many more
Lt.Dan is offline
post #5 of 8 (permalink) Old 07-23-2017, 09:09 PM Thread Starter
I think it must have come from a manual, because I don't have any lift and I pulled it as far is it could go and it still didn't connect.
GAobs is offline
post #6 of 8 (permalink) Old 07-23-2017, 09:29 PM
Bugman's Avatar
Take the drive shaft to a drive line shop and have them lengthen it. They will tell you what the measurements are that you need to do.
This will be a lot easier than trying to find a correct drive line if you can't reuse your old one..
Bugman is offline
post #7 of 8 (permalink) Old 07-23-2017, 10:49 PM Thread Starter
Yeah that's basically what my dad said to do I just wanted to make sure there weren't any other issues or things I was overlooking, also I thought I read that there was issues with the f350 driveshaft on the f250 transfer case? But if not I'll just get it lengthened
GAobs is offline
post #8 of 8 (permalink) Old 07-24-2017, 03:35 PM
That is correct also. The yoke that goes into the transfer case is different between the 250 and 350 because of the different u joint used on the drive shaft. I couldn't find the correct 350 one when I did my conversion. I found one that was close and had to modify it some to make it work. I guess someone found a bunch of new ones and bought them, but I don't remember who.
96 F250 CCSB 4x4, D60, 3.55, Auto, 6.0 trans cooler 3"-4" down pipe & exhaust, not enough power
wildstang is offline
