AE Data - PowerStrokeNation : Ford Powerstroke Diesel Forum
 1Likes
post #1 of 12 (permalink) Old 07-14-2017, 08:25 PM Thread Starter
SE_Georgia's Avatar
AE Data
Good Afternoon,
So I finally got AE to connect to my 94.5 PSD. Anyone care to take a look at the data and provide inputs?
Thanks
File Type: csv Ford-PowerStroke 7.3L-1995-July 14 2017 stock.csv (50.8 KB, 22 views)
1994.5 F250 4x4 SuperCab, 7.3 PSD, ZF5, 4.10 gears, PAC Brake, 6637, Wicked Wheel 2, Hydra, Autometer Pyro and Boost Gauges.
2002 F350 DRW 2wd, Automagic, 4.10 gears, Hydra
Si Vis Pacem, Para Bellum
SE_Georgia is offline
post #2 of 12 (permalink) Old 07-18-2017, 08:55 PM Thread Starter
SE_Georgia's Avatar
Re: AE Data
Anyone?
post #3 of 12 (permalink) Old 07-18-2017, 10:02 PM
Native Texan
masakimm's Avatar
Garage
Re: AE Data
Originally Posted by SE_Georgia View Post
Anyone?
I would but I have to wait till I get how can't open it on my phone.
Sent from my Super awesome outdated Samsung that doesn't burst into flames using Tapatalk
Upgrades:
masakimm is online now
post #4 of 12 (permalink) Old 07-19-2017, 06:05 PM
drick1lsu's Avatar
Garage
Re: AE Data
Looks like you have lack of boost....only 9.4 psi. Probably a leak. Map sensor seems to be reading ambient air pressures fine. You can get a boost leak detector from diesel site to help (I did this and it worked really well) or just look go over the truck with a fine toothed comb. All other readings seem to be as they should.
Hope this helps
1995 F-250 single cab. 4"lift and level. D60 Swap. 3"mbrp down pipe to 4"muffler exhaust. S&B intake. Swamps tuned T6. Baby Swamps Injectors. Swamps HVHF IDM. Adrenaline HPOP. 1.0 AR Exhaust, Wicked Wheel, e99 spider w/ Superduty Intercooler. Sinister Diesel Coolant Filter. Amsoil Secondary Oil Filter. Mickey T 16x9 and 35 MT
drick1lsu is offline
post #5 of 12 (permalink) Old 07-23-2017, 08:35 PM
Project Shamu
Lt.Dan's Avatar
Re: AE Data
What problems are you having? Lack of power? Misfire? Or just curious?
It would just help to know what we are looking for.
1996 Cali F350 CCFB, 7.3 PSD, 2wd SAS, w/ 380,000 miles.
New Motor at 352,000, DieselSite Legendary Trans at 356,000 and many more
Lt.Dan is offline
post #6 of 12 (permalink) Old 08-04-2017, 03:00 PM Thread Starter
SE_Georgia's Avatar
Re: AE Data
Not having any noticeable problems, just finally got AE to connect and wanted to get input from the community. Maybe head off some issues if someone noticed something out of place.
I was curious about those boost numbers. I Bought boost gauge and it barely gets above 10, so I probably have a leak someone where.
post #7 of 12 (permalink) Old 08-04-2017, 03:02 PM Thread Starter
SE_Georgia's Avatar
Re: AE Data
Thanks. I was thinking the boost was low.
post #8 of 12 (permalink) Old 08-04-2017, 03:41 PM
Re: AE Data
On a stock truck, I wouldn't expect to see it go above 10 psi more than occasionally. 'Course, maybe I have boost leaks.....
madpogue is offline
post #9 of 12 (permalink) Old 08-05-2017, 07:02 PM
Project Shamu
Lt.Dan's Avatar
Re: AE Data
A stock truck should build 15-17psi MAX. I'm talking, loaded for max weight, climbing a 7% grade.
Around town, a stock truck will build maybe 12-13psi.
Lt.Dan is offline
post #10 of 12 (permalink) Old 08-05-2017, 09:17 PM Thread Starter
SE_Georgia's Avatar
Re: AE Data
So I built a boost leak tester today. 6" long piece of 3" PVC, a 3" PVC cap, drilled hole and screwed in male air compressor fitting. I installed it on the flexible intake hose to the turbo (the one that is red on non modified trucks). Pushed in about 15 psi using the regulator on my compressor and comparing to boost gauge. It was easy to find the leak between the turbo and the Y pipe. Replaced the gasket and getting good boost now. The air compressor gauge and the boost gauge matched after I fixed the leak.
drick1lsu likes this.
