5 speed swap - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 15 (permalink) Old 07-10-2017, 05:34 PM Thread Starter
5 speed swap
Hi guys new to this page. I have a 96 f450 2wd auto powerstroke and I'm wondering if a 5 speed tranny out of a 95 f350 4x4 powerstroke would bolt in or what all would have to be changed and what all I would need to do it. Any help would be appreciated. Thanks in advance
Fordguy97 is offline
post #2 of 15 (permalink) Old 07-10-2017, 06:37 PM
alleged moderator
tjctransport's Avatar
Re: 5 speed swap
welcome to PSN.
yes it will bolt up, but you will also have to use the transfer case.
you would be better off looking for a two wheel drive trans. they are usually a lot cheaper than the 4X4 trans.
tom
tjctransport is offline
post #3 of 15 (permalink) Old 07-10-2017, 09:39 PM
Because I can!!!
Thatchevyguy's Avatar
Re: 5 speed swap
X2 look for a 2wd trans
97 F350 cclb
7.3 5spd
95 f350 rclb 7.3
02 f350 ccsb 7.3
Thatchevyguy is offline
post #4 of 15 (permalink) Old 07-10-2017, 09:53 PM
Bugman's Avatar
Re: 5 speed swap
A 4x4 trans and transfer case would be sweet if you ever needed a real low gear for backing a trailer up a hill or getting something moved.
Bugman is offline
post #5 of 15 (permalink) Old 07-10-2017, 10:12 PM
Re: 5 speed swap
Do you have access to the rest of the donor truck?
madpogue is offline
post #6 of 15 (permalink) Old 07-11-2017, 02:20 AM Thread Starter
I do have the whole donor truck I was hoping that the back of my auto would bolt up to the 5 speed instead of the transfer case the bolt holes look to be about the same and I do have the driveline brake on the back of my auto trans
post #7 of 15 (permalink) Old 07-11-2017, 03:48 AM
Schneider 86's Avatar
Re: 5 speed swap
Well you said that you have an F450. Since they didn't make a 450, I'm assuming you have an F-Superduty (which is the next size larger than the F-350). If this is the case, you're in luck as the F-Superduty actually used the 4x4 ZF 5 from the factory. And instead of a transfer case, they had the parking brake assembly bolted on. So then you actually would need the 4x4 trans, and switch your parking brake assembly. Hope this makes sense....
Schneider 86 is offline
post #8 of 15 (permalink) Old 07-11-2017, 06:34 AM
Re: 5 speed swap
^^^^^ Good read. Actually, ONLY a 4x4 transmission would work in this truck; a 2WD tranny would not.
madpogue is offline
post #9 of 15 (permalink) Old 07-11-2017, 10:24 AM
alleged moderator
Re: 5 speed swap
yea, i missed that too. i read it as F350. as was already said, the F-superduty uses a 4X4 trans with the parking brake assembly bolted to the back where the transfer case should be.
tom
post #10 of 15 (permalink) Old 07-11-2017, 11:37 AM Thread Starter
Awesome that's what I was hoping to hear thanks again
