Bad cam 7.3? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 10 (permalink) Old 07-06-2017, 01:11 PM Thread Starter
Bad cam 7.3?
People that I have spoken with about the problems my truck is having say that they have never seen a bad cam in a 7.3. Not getting any compression from one valve. Seems like the cam could be wiped - Lose almost all the way around then when it gets to the top it finally tightens up
smann23 is offline
post #2 of 10 (permalink) Old 07-06-2017, 01:40 PM
Master BS'er
jamiesaun's Avatar
Re: Bad cam 7.3?
I'm not too familiar with the 7.3 but I'm assuming it's got hydraulic lifters? That's probably more likely, but it could be a bad lobe.
If the lifters is fine and nothing's bent, then yeah, the lobe is shot.
Brother James
Ps...Im pretty frickin awesome!
jamiesaun is offline
post #3 of 10 (permalink) Old 07-06-2017, 02:12 PM
Moderator
Sbluke55's Avatar
Re: Bad cam 7.3?
I would inspect the push rod first. Then I would pull the head. I don't think you can get to the lifter with it on. Does the valve stick up as high as the others.
01 f-250, Standard
Sbluke55 is offline
post #4 of 10 (permalink) Old 07-10-2017, 01:32 AM
Project Shamu
Lt.Dan's Avatar
Re: Bad cam 7.3?
I vote push rod as well, a little more common than a cam.
I've only heard of a cam breaking once, and it broke in 3 places, as well as the crank, and the block...
1996 Cali F350 CCFB, 7.3 PSD, 2wd SAS, w/ 380,000 miles.
New Motor at 352,000, DieselSite Legendary Trans at 356,000 and many more
Lt.Dan is offline
post #5 of 10 (permalink) Old 07-10-2017, 02:50 AM
Native Texan
masakimm's Avatar
Garage
Re: Bad cam 7.3?
And if it is a wiped cam what caused it to wipe most likely has a head problem. Ie stuck valve that is most common cause of cam failures.
Sent from my SAMSUNG-SM-G935A using Tapatalk
Upgrades:
masakimm is offline
post #6 of 10 (permalink) Old 07-10-2017, 04:05 AM
Moderator
Sbluke55's Avatar
Re: Bad cam 7.3?
The 7.3 has the same lifters as the 6.0 and 6.4. They have been know to wipe out a cam. The main reason is the cam profile is pretty aggressive in the 6.0 causing the lifter to jump and start to break the roller. I've never heard about a 7.3 having that issue but it's possible.
01 f-250, Standard
Sbluke55 is offline
post #7 of 10 (permalink) Old 07-10-2017, 04:27 AM
Project Shamu
Lt.Dan's Avatar
Re: Bad cam 7.3?
I vaguely remember reading somewhere the lifter for our 7.3 is the same in a LOT of v8 engines out there, most commonly being the Chevy 350.
Lt.Dan is offline
post #8 of 10 (permalink) Old 07-10-2017, 04:28 AM
Master BS'er
jamiesaun's Avatar
Re: Bad cam 7.3?
Although wiping out a cam lobe is fairly rare, it does happen. I've seen it several times, usually from a roller seizing up or lack of oil or both. I've only seen one cam break, but that was do to not torqing in the correct sequence.
It's a fairly simple process. Pull the valve covers, if nothing's bent then turn the engine over, by hand or cranking and watch the rockers. Find the one that doesn't move and get some eyes on the lifter. If it's pumped up, you got a bad cam.
Brother James
post #9 of 10 (permalink) Old 07-10-2017, 04:35 AM
Native Texan
masakimm's Avatar
Garage
Re: Bad cam 7.3?
Yeah i have seen 6.0l wipe cams when lifters fail but have never seen it in a 7.3l I have seen valve failures in 7.3l. But there's always a first time for anything.
Upgrades:
masakimm is offline
post #10 of 10 (permalink) Old 07-10-2017, 04:50 AM
Master BS'er
jamiesaun's Avatar
Re: Bad cam 7.3?
Someone mentioned installed height. That's a really good point, pay close attention to that because it's very hard to see the difference sometimes. Though I suspect a hanging valve would do some very noticeable damage in a diesel, but still look out for it. It could be hanging a tiny bit.
Brother James
