gregs 97 - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 3 (permalink) Old 07-01-2017, 05:58 PM Thread Starter
gregs 97
I use my trk daily in my work, drove to lowes for materials engine lite came on truck would not take fuel , let off pedal lite goes out and engine taking fuel again but trans. seems to shift into high gear real quick. went home check for codes and truck thru a throttle positioning senser code, replaced that and still have the same problem. can anyone help me please.
gregs 97 is offline
post #2 of 3 (permalink) Old 07-01-2017, 08:42 PM
Re: gregs 97
What was the actual code?
Did you TEST the APS? What brand of replacement did you buy, and did you TEST that? Also, did you check the IVS?
madpogue is offline
post #3 of 3 (permalink) Old 07-01-2017, 09:03 PM
alleged moderator
tjctransport's Avatar
Re: gregs 97
welcome to PSN.
a bad throttle position sensor will do the same thing.
i had to put three new ones in my 02 before i got a good one. the third came rite from ford. the other two were from NAPA.
tom
tjctransport is offline
