95 F350 - PowerStrokeNation : Ford Powerstroke Diesel Forum
 3Likes
post #1 of 11 (permalink) Old 06-21-2017, 03:24 AM Thread Starter
mud.princess's Avatar
95 F350
Do y'all know what the sensor on the left is?
mud.princess is offline
post #2 of 11 (permalink) Old 06-21-2017, 03:34 AM
Moderator
Sbluke55's Avatar
Re: 95 F350
I believe oil temp.
01 f-250, Standard
Sbluke55 is offline
post #3 of 11 (permalink) Old 06-21-2017, 03:34 AM
Native Texan
masakimm's Avatar
Garage
Re: 95 F350
Well im not sure since my 95 doesnt have it. Possably for an aftermarker gauge.
Sent from my Super awesome outdated Samsung that doesn't burst into flames using Tapatalk
Upgrades:
masakimm is offline
post #4 of 11 (permalink) Old 06-21-2017, 03:41 AM
Bugman's Avatar
Re: 95 F350
The one on the left is for the coolant overheating light. The one on the right is for the coolant temperature gauge
mud.princess likes this.
Bugman is offline
post #5 of 11 (permalink) Old 06-21-2017, 03:55 AM Thread Starter
Re: 95 F350
Thank you!!! Where's the best place to buy that?
post #6 of 11 (permalink) Old 06-21-2017, 04:21 AM
Bugman's Avatar
Re: 95 F350
I'd just pick it up at NAPA. Just make sure that the one you get is for a light and not the gauge.
Bugman is offline
post #7 of 11 (permalink) Old 06-21-2017, 04:23 AM
Moderator
Sbluke55's Avatar
Re: 95 F350
Damn. I was less right.
(I'm not ever wrong, just less right)
At least I got the temperature sender right. Just the incorrect fluid. Truthfully that is the first time I've seen one.
Bugman likes this.
01 f-250, Standard
Sbluke55 is offline
post #8 of 11 (permalink) Old 06-21-2017, 04:39 AM Thread Starter
Re: 95 F350
I can't find any online, would it be called anything other than the coolant overheating light?
(Not these, correct?)
post #9 of 11 (permalink) Old 06-21-2017, 05:36 AM
Bugman's Avatar
Re: 95 F350
I found what I think it is on NAPA's web site by cross referencing the Ford part number but I gagged some when I saw the price.
Here it is
The Ford part number for it is F4TZ-10884-B but Ford shows it as a discontinued part. You could try that number at a dealer and see what they come up with and see what their price is.
I think that if it was me with what it cost I just might plug the hole or not worry about it. All it is for is the light on the dash that tells you that the engine is overheating so if you watch your temperature gauge you would be alright.
Bugman is offline
post #10 of 11 (permalink) Old 06-26-2017, 03:16 AM
Project Shamu
Lt.Dan's Avatar
Re: 95 F350
When I had my motor rebuilt, they didn't give me that sensor back, and I fought trying to even find out what it was. After I followed the wiring harness I realized it was the temp sensor, but no part stores could find it, they would only come up with the one for the gauge.
I just put a plug in the hole and taped the plug up, no lights on the dash, no harm no foul.
Sent from my iPad using Tapatalk
1996 Cali F350 CCFB, 7.3 PSD, 2wd SAS, w/ 380,000 miles.
New Motor at 352,000, DieselSite Legendary Trans at 356,000 and many more
Lt.Dan is offline
