motor mount coolant leak - PowerStrokeNation : Ford Powerstroke Diesel Forum
 1Likes
post #1 of 14 (permalink) Old 06-14-2017, 01:17 PM Thread Starter
Drivers side motor mount looks like coolant is leaking out. Have a six inch diameter spot every morning. Bolt right next to the oil filter. I rebuilt this truck but am i in some trouble if its coming out there??? Just take it out and put some thread dop on it? And no the cooler is not leaking it is dry along with the freeze plugs and everywhere else. Put over 1000 miles on and it just started. Thanks guys cheers
Rawdog is offline
post #2 of 14 (permalink) Old 06-14-2017, 01:19 PM
410customs's Avatar
Re: motor mount coolant leak
the bolt next to the oil filter or the coolant drain port next to the oil filter?
2001 Excursion 7.3, auto, 4x4, 3.73, 6" Suspension lift, 37" Dick Cepeks
2000 E350 7.3, auto 2wd, 3.73, planning a TTB 4x4 conversion
21.9 liter family
410customs is offline
post #3 of 14 (permalink) Old 06-14-2017, 01:21 PM Thread Starter
Motor mount bolt in front of the coolant drain bolt
Rawdog is offline
post #4 of 14 (permalink) Old 06-14-2017, 01:38 PM
Master BS'er
jamiesaun's Avatar
engine mount is leaking coolant?
Brother James
Ps...Im pretty frickin awesome!
jamiesaun is offline
post #5 of 14 (permalink) Old 06-14-2017, 01:49 PM Thread Starter
Ya above it is dry along with all the plugs . coming out around the bolt..
Sent from my DROID RAZR HD using Tapatalk
Rawdog is offline
post #6 of 14 (permalink) Old 06-14-2017, 01:53 PM Thread Starter
Just for views.. Stripped this dually dump truck right to the frame
Rawdog is offline
post #7 of 14 (permalink) Old 06-14-2017, 02:06 PM
Native Texan
masakimm's Avatar
Garage
There is a freeze plug behind the mount also.
masakimm is offline
post #8 of 14 (permalink) Old 06-14-2017, 02:10 PM Thread Starter
That ones fine also
Rawdog is offline
post #9 of 14 (permalink) Old 06-14-2017, 02:16 PM
410customs's Avatar
pull the bolt? see what happens
I do not think engine mount bolts go into the water jacket, but if they do they would require thread sealer
next step would be to try a dye kit logic says it is coming from above or behind
21.9 liter family
post #10 of 14 (permalink) Old 06-14-2017, 02:17 PM Thread Starter
Ok man thanks ill see what i can do
Rawdog is offline
